Problems with Speed <yet again>
- ADSL Broadband
- Re: Problems with Speed <yet again>
30-03-2009 9:11 PM
In the past Ive had problems with the speed of my internet.
It was resolved by plusnet putting me on an adsl max line..
A couple of days ago I have noticed the speed of my net go slower during the evenings.. so this is about 7pm onwards... during the day It is fine.
Here is a speedtest done 5minutes ago.. Anybody have a clue on what is going on? During the day my net is fine but when it comes to 7pm+ it gets slow..
Message 1 of 4
(618 Views)
3 REPLIES 3
30-03-2009 9:38 PM
What speed do you normally get plus what line speed does your router currently say?
Message 2 of 4
(96 Views)
30-03-2009 10:04 PM
I normally get speeds : UpStream Connection Speed 448 kbps
How do I find out the line that my router currently has?
Message 3 of 4
(96 Views)
31-03-2009 12:54 AM
follow the instructions on here for you make and model of router. http://www.kitz.co.uk/adsl/frogstats.php
post the sync speeds,line attention, snr/noise margin
also what is your ip profile check the bt one here http://www.speedtester.bt.com/ login using this (yourPNusername @plusdsl.net) and the PN one here(you need to be logged into PN to see it) https://portal.plus.net/my.html?action=data_transfer_speed
Message 4 of 4
(96 Views)
- ADSL Broadband
