Problems with Port Forwarding?
- Re: Problems with Port Forwarding?
03-03-2014 4:57 PM
Hello, I seem to have trouble with forwarding ports for a few games (GGPO and Guilty Gear XX: Reload). My ports seem to be set up properly in my router page, but the ports themselves seem to be closed, no matter what I try. I also have both applications running while testing the ports. I've had to enable DMZ and Game Mode temporarily for both games to work for the time being. Windows Firewall seems to be working fine, has the correct permissions ticked.
Any advice would be great, thanks.
Message 1 of 4
(592 Views)
3 REPLIES 3
04-03-2014 1:32 AM
Have you seen
http://npr.me.uk/forwardports.html
Message 2 of 4
(365 Views)
04-03-2014 8:59 AM
That does the same a DMZ which is now in the routers GUI.
Message 3 of 4
(365 Views)
04-03-2014 9:04 AM
Which router are you using? Is it the Technicolor 582n.
Message 4 of 4
(365 Views)
