Problem uploading files to web sites (madasafish/freenetname)
- Re: Problem uploading files to web sites (madasafi...
26-08-2011 9:18 AM
Whilst my upload speed is only around 330 kbps (confirmed by speed test) I wouldn't expect it to take this long - it used to be much quicker.
Also, when I FTP files, they transfer much quicker.
I remember about 12 months ago madasafish users were accidentally subjected to traffic management - has something similar happened again?
Re: Problem uploading files to web sites (madasafish/freenetname)
26-08-2011 9:58 AM
Traffic management only works on the downstream so that should not be a factor.
Also I have to say that 330kbps is about right for the broadband product you have with us. I'd perhaps consider checking your firewall settings.
Adam
26-08-2011 10:20 AM
I just can't work out why it's so much slower using a web site's upload process that it is FTP'ing.
I just thought I'd check if there was anything obvious as I've got to upload around 40Mb of files on Tuesday with FTP not being an option (potentially 3.5 hours).
I'll double check things at my end when I get home tonight.
26-08-2011 4:57 PM
27-08-2011 10:44 AM
I think it's time to raise a ticket.
29-08-2011 6:37 PM
Noticed that recently my upload speed became miserable. Tried to upload a few photos to Facebook, waited for 15 minutes - nothing, cancelled it. After that tried to upload single picture to Google+ - they have progress indicator, waited for 5 minutes - it didn't even move. At the same time the download speed is decent, don't have any complains about it.
I reset my router - still the same.
I need help, thanks
30-08-2011 8:28 PM
Are these upload speeds with wireless or ethernet?
Jojo
04-09-2011 8:12 PM
04-09-2011 8:56 PM
The download is fine (6-8 mB/s). Computer is iMac.
I cannot upload anything above a tiny image to my website, I can't send attachments with emails and I'm totally fed up. Its affecting my business and I feel locked into a contract that is not delivering.
Can anyone help? Plusnet appear helpless (or do I mean hopeless?)
It was not like this before I migrated to Plusnet.......
Tips, ideas gratefully received.
Simon
05-09-2011 2:57 PM
@Burjua - Please could you try the same test on a wired connection to make sure it's not the wireless connection causing the slowdown?
@tequillaboy - I can't see anything on your account that looks like a problem, the upload profile is still 448 according to the BT reporting. Are you seeing any reduction in the upload sync speed, and could you post some results from the BT speed tester (http://www.speedtester.bt.com) please?
