Problem accessing particular website
- Problem accessing particular website
19-07-2009 1:40 PM
Hi
I've been unable to access a forum at www.yacf.co.uk for a couple of days, though I haven't seen the problem with any other site I've tried to load. However, I can log into the forum via my mobile and I can see that posts have been made today - so it looks like the site is running.
I haven't changed connection or router settings for a while, so I'm puzzled why I can't see the site. Because other browsing doesn't seem to be affected, I don't think that it's a local problem. A tracert (pasted below) shows a time out after 8 hops. Pinging the site shows 4 timeouts.
Any ideas?
Thanks. Peter
C:\>tracert www.yacf.co.uk
Tracing route to www.yacf.co.uk [81.31.99.15]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 32 ms 30 ms 29 ms lo0-plusnet.pcl-ag02.plus.net [195.166.128.39]
3 34 ms 32 ms 33 ms gi1-2-904.pcl-gw02.plus.net [84.92.0.141]
4 61 ms 34 ms 29 ms te2-1.pcl-gw01.plus.net [212.159.1.113]
5 30 ms 44 ms 39 ms te2-2.pte-gw1.plus.net [212.159.0.186]
6 29 ms 29 ms 29 ms lonap2.enta.net [193.203.5.135]
7 37 ms 51 ms 45 ms te5-3.gs1.core.enta.net [78.33.35.218]
8 31 ms 32 ms 33 ms te1-1.interxion.core.enta.net [87.127.236.86]
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * ^C
Any ideas?
Thanks. Peter
13 * ^C
Message 1 of 7
(1,358 Views)
6 REPLIES 6
Re: Problem accessing particular website
19-07-2009 1:57 PM
Which gateway are you on?
Looks OK to me on "City Lifeline, Juniper 10" gateway. This gateway is sometimes known as pcl-ag03.
$ mtr -rc 20 www.yacf.co.uk
HOST: gorgonzola Loss% Snt Last Avg Best Wrst StDev
1. home.gateway 0.0% 20 1.9 0.6 0.4 1.9 0.5
2. lo0-plusnet.pcl-ag03.plus.ne 0.0% 20 31.3 36.2 24.7 117.7 24.5
3. gi1-6-703.pcl-gw01.plus.net 0.0% 20 30.0 33.8 25.5 45.8 6.3
4. te2-2.pte-gw1.plus.net 0.0% 20 24.0 28.0 24.0 37.4 3.7
5. lonap1.enta.net 0.0% 20 125.6 37.4 23.4 125.6 28.7
6. te5-3.telehouse-east2.core.e 0.0% 20 29.8 37.2 26.5 184.1 34.6
7. te5-3.gs1.core.enta.net 0.0% 20 28.6 35.5 24.4 65.0 10.4
8. te1-1.interxion.core.enta.ne 0.0% 20 28.4 31.6 24.6 48.2 5.6
9. freeolaweb5.freeola.com 0.0% 20 26.5 28.8 25.7 34.3 2.6
Message 2 of 7
(589 Views)
19-07-2009 2:07 PM
Hi Waldo
I'm on - "City Lifeline, Juniper 9" gateway. This gateway is sometimes known as pcl-ag02.
Message 3 of 7
(589 Views)
19-07-2009 2:28 PM
no problem here FF3.5.1 XP SP3 "Telehouse North, Juniper 2" gateway. This gateway is sometimes known as ptn-ag2.
Message 4 of 7
(589 Views)
19-07-2009 3:04 PM
Quote from: deuxchevaux I'm on - "City Lifeline, Juniper 9" gateway. This gateway is sometimes known as pcl-ag02.
Can you login to your router and disconnect for a couple of minutes?
Hopefully when you reconnect you'll be on a different gateway (which may or may not solve the problem).
Message 5 of 7
(589 Views)
19-07-2009 3:09 PM
Hi Waldo,
I beat you to it!
I just rebooted my router and am now connected to a different gateway ("City Lifeline, Juniper 10" gateway. This gateway is sometimes known as pcl-ag03). Can now access the site, so problem fixed (or rather, worked around). I'll know to try this earlier next time.
Thanks for your help!
Peter
adie:quote
I beat you to it!
Peter
adie:quote
Message 6 of 7
(589 Views)
19-07-2009 3:46 PM
Quote from: deuxchevaux I beat you to it!
Heh! Some of us are just s l o w
Quote I just rebooted my router and am now connected to a different gateway [.....] I'll know to try this earlier next time.
Don't go doing it too often - it can look to the BT equipment at the exchange that your line is unstable and result in a lower sync speed when you reconnect.
Message 7 of 7
(589 Views)
