Problem accessing GoDaddy Hosted Websites
robbo100
Hi all,
Is anyone else having problems reaching websites hosted by GoDaddy using their plusnet ISP ADSL/Fibre connection?
I have two sites hosted with them, and about 4 days ago, all access stopped! I can't administer my sites and I am worried that it is going to start impacting my business.  Cry
Can anyone reach www.piandbash.co.uk?
If I do a traceroute, I get the following:
Traceroute has started…
traceroute to piandbash.co.uk (184.168.47.225), 64 hops max, 72 byte packets
1  dsldevice (192.168.1.1)  24.860 ms  2.198 ms  1.339 ms
2  lo0-central10.ptn-ag01.plus.net (195.166.128.190)  22.685 ms  37.473 ms  17.927 ms
3  link-b-central10.ptn-gw02.plus.net (212.159.2.130)  12.576 ms  12.753 ms  12.423 ms
4  xe-5-2-0.ptw-cr02.plus.net (212.159.0.106)  12.798 ms  16.989 ms  13.335 ms
5  ae2.ptw-cr01.plus.net (195.166.129.4)  13.913 ms  15.102 ms  13.732 ms
6  195.66.225.28 (195.66.225.28)  20.258 ms  19.586 ms  20.193 ms
7  * * *
Rob
29 REPLIES 29
Jaggies
Re: Problem accessing GoDaddy Hosted Websites
Quote from: robbo100
Works fine here.
Fixes: 1,483
all working ok here on a pn connection and via vpn.
Oldjim
Resting Legend
Fixes: 63
I can't either
C:\Users\Jim>tracert www.piandbash.co.uk
Tracing route to piandbash.co.uk [184.168.47.225]
over a maximum of 30 hops:
 1    <1 ms    <1 ms    <1 ms  dsldevice.lan [192.168.1.254]
 2    38 ms    40 ms    32 ms  lo0-central10.pcl-ag04.plus.net [195.166.128.185]
 3    33 ms    32 ms    34 ms  link-a-central10.pcl-gw01.plus.net [212.159.2.172]
 4    34 ms    75 ms    35 ms  xe-0-2-0.pcl-cr01.plus.net [212.159.0.204]
 5    33 ms    57 ms    32 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
 6    40 ms    40 ms    40 ms  195.66.225.28
 7     *        *        *     Request timed out.
 8     *        *        *     Request timed out.
 9
Fixes: 1,483
i can get to it but traceroute is the same:
traceroute to piandbash.co.uk (184.168.47.225), 64 hops max, 52 byte packets
1  192.168.1.254 (192.168.1.254)  743.841 ms  7.595 ms  2.553 ms
2  lo0.11.central11.ptw-bng02.plus.net (195.166.130.204)  20.118 ms  18.782 ms  18.887 ms
3  irb.11.ptw-cr01.plus.net (84.93.249.17)  21.811 ms
    irb.11.ptw-cr02.plus.net (84.93.249.18)  20.443 ms  19.739 ms
4  ae2.ptw-cr01.plus.net (195.166.129.4)  17.916 ms  72.796 ms
    195.66.225.28 (195.66.225.28)  27.508 ms
5  195.66.225.28 (195.66.225.28)  26.852 ms  27.370 ms *
6  * * *
7  * *^C
AndyH
Are you both on 20CN?
Fixes: 1,483
i'm not.
robbo100
I am on Fibre
robbo100
How about www.pinventor.co.uk?
Is that any better/worse?
Bud
on plusnet 20CN here and I can get to the site, but get a different traceroute.
 1   100 ms    94 ms    99 ms  10.0.10.10
 2    50 ms    60 ms    50 ms  lo0-central10.ptn-ag01.plus.net [195.166.128.190
 3    50 ms    50 ms    51 ms  link-a-central10.ptn-gw01.plus.net [212.159.2.12
8]
 4    50 ms    50 ms    49 ms  xe-5-2-0.ptw-cr01.plus.net [212.159.0.104]
 5    58 ms    57 ms    57 ms  195.66.225.28
 6     *        *        *     Request timed out.
 7   200 ms   200 ms   201 ms  ip-184-168-0-86.ip.secureserver.net [184.168.0.8
6]
 8   200 ms   200 ms   200 ms  te0-0-0-7.trmc0215-01.ars.mgmt.phx3.gdg [184.168
.0.85]
 9   205 ms   201 ms   202 ms  ip-97-74-255-129.ip.secureserver.net [97.74.255.
129]
10   199 ms   199 ms   199 ms  redirect-v225.secureserver.net [184.168.47.225]
Trace complete.
spraxyt
Resting Legend
Fixes: 75
I'm on fibre and can get to the site. Tracert also works
C:\>tracert www.piandbash.co.uk
 1    <1 ms    <1 ms    <1 ms  192.168.1.254
 2    26 ms    26 ms    27 ms  lo0-central10.ptn-ag03.plus.net [195.166.128.192]
 3    26 ms    28 ms    25 ms  link-b-central10.ptn-gw02.plus.net [212.159.2.138]
 4     *       26 ms    32 ms  xe-5-3-0.ptw-cr02.plus.net [212.159.0.110]
 5    26 ms    25 ms    28 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
 6    33 ms    32 ms    32 ms  195.66.225.28
 8   176 ms   176 ms   177 ms  ip-184-168-0-86.ip.secureserver.net [184.168.0.86]
 9   177 ms   177 ms   177 ms  te0-0-0-7.trmc0215-01.ars.mgmt.phx3.gdg [184.168.0.85]
10   196 ms   177 ms   177 ms  ip-97-74-255-129.ip.secureserver.net [97.74.255.129]
11   176 ms   175 ms   176 ms  redirect-v225.secureserver.net [184.168.47.225]
Trace complete.
David
Oldjim
Resting Legend
Fixes: 63
Same - I can't get to that either
On 21CN
robbo100
Hmmm,
Thanks for everyone for trying.
So does anyone have a view on what might be causing this problem?
Rob
AndyH
It looks like possibly a problem with GoDaddy/Linx - https://www.linx.net/pubtools/member-techinfo/member_id/100698
Can you try disconnecting/reconnecting? If you land on a different gateway, it might make a difference.
robbo100
I already spoke to GoDaddy, and told them that the first return on a google search, for the last IP on my traceroute, mentioned GoDaddy, and they said that it wasn't one of their systems. All other google hits for that IP address say it is from London Internet Exchange Limited.
GoDaddy said that it wasn't a problem at their end, and all other ISPs can reach their websites, so it must be something at my ISP.
I have tried disconnecting and reconnecting, and I still get the same problem.
I am very confused! I do hope this gets sorted soon!
Hmmm
