Problem: The following addresses were found in both the approved and blocked...
- Problem: The following addresses were found in bot...
04-04-2008 3:36 PM
I was just wondering if this was a common fault as its still early stages?
Ive tried leaving the approved list empty and enter ONLY in the blocked addresses, but it keeps giving the following error;
The following addresses were found in both the approved and blocked senders lists:
Re: Problem: The following addresses were found in both the approved and blocked...
04-04-2008 3:36 PM
04-04-2008 5:09 PM
I am getting the same message but I am trying to add a good address to the approved addresses list. I have nothing in the blocked addresses box
04-04-2008 5:15 PM
We're in the process of fixing it now but you can get around it by entering a line space in the approved or blocked sender field I think.
04-04-2008 6:13 PM
Quote from: Bob
Also works OK if you don't use Enter (Newline) at the end of the final line.
05-04-2008 7:22 PM
07-04-2008 8:02 AM
Quote There was a problem
Unfortunately there has been an error updating your details.
Please try again in a few minutes, if the problem continues please contact our support team so we may investigate.
Tried a fair few times
08-04-2008 3:49 PM
Can this be increased at all?
08-04-2008 3:51 PM
Quote there appears to be a limit of 256 emails allowed in the blocked addresses section
There is actually a character limit of 1024 rather than a number of addresses, AFAIK there isn't a way to increase this.
08-04-2008 4:00 PM
Ex-Broadband Service Manager
08-04-2008 4:01 PM
Quote Is that a limit by Postini?
Yes.
08-04-2008 4:05 PM
I have a collection of 300/400 addresses from all employees which id like to block at the F9/Postini end, it would just save our bandwidth if I could block all these.
I guess I will have to leave it there and just add the serious contenders to the F9 list.
08-04-2008 4:34 PM
08-04-2008 4:55 PM
08-04-2008 6:09 PM
