Problem Extending wifi using Netgear WN1000DP
FIXEDTopic Options
- Re: Problem Extending wifi using Netgear WN1000DP
21-02-2014 11:27 AM
Using the standard technicolour router and need to extend its range ( they didn't deliver the extension cable when I had the modem and router installed yesterday!!!!). Using a Netgear WN1000DP I can recognise it with the router, and vice versa, but can't get wifi access to it. It comes back, 'windows unable to access it........'. I have previously used the Netgear device with my last router.
Any help would be appreciated!!!
Fixed! Go to the fix.
Message 1 of 4
(886 Views)
3 REPLIES 3
21-02-2014 2:20 PM
Have you turned off the dhcp server on the Netgear? you might want to give it a lan ip address of 192.168.1.2 for example so you can reach it from the same ip range as the TG582n. Turn off the wifi on the TG582n while you get the Netgear settled if you have the router wired to pc.
Message 2 of 4
(652 Views)
21-02-2014 10:12 PM
Thanks for getting back to me............finally sorted it out..........I was just making it complicated for myself!!!!!
Message 3 of 4
(652 Views)
22-02-2014 1:46 PM
Would you mind posting what the problem was?
There's nothing worse when searching for a problem than finding abandoned threads!
Message 4 of 4
(652 Views)
