Problem: Activation Date
- Problem: Activation Date
16-02-2009 11:38 AM
So I'm migrating over to PlusNet from O2 because the pings and speeds are absolutely horrific after moving to them from ADSL24 about 2 weeks ago.. I decide to move to you guys, however, when you register to migrate, the dropdown box that says about the date you want to move, it says "As soon as possible" then the earliest date after that was "20th February 2009" which is this Friday..
So I thought, hey if I select "As soon as possible" that will mean maybe Thursday? Or at least Friday at the latest as it's already stated there that is the earliest they can do it! Great, I'll pick that just in case I can get a day early, if not, Friday (20th) is fine.
So I get a confirmation email - I'm due activation on Monday, the 23rd February.
Please explain this for me? I need to move ASAP, which is why I selected "As soon as possible", not 3 days after the earliest date you stated.. I was really chuffed and wanted to get away from O2 as quick as possible as the connection is useless, there speeds and pings are dire..
Many thanks.
Re: Problem: Activation Date
16-02-2009 11:52 AM
I'm sorry that this isn't going to happen as soon as you were hoping that it was going to.
Part of this is down to your order being placed at the weekend, which means that for all intents and purposes, as far as BT are concerned, the order isn't placed until Monday, the first working day after your order is submitted. From there, it takes a full 5 working days (ie: a week) which means that your order is completed the following Monday.
I'm afraid that by cancelling your order, it would make the MAC Code invalid so I would have no way of resubmitting your order. It is technically possible to resubmit a order with a shorter lead time, but that would mean that you would need to get a new MAC Code from O2. If you feel that you would be able to do that, I would be happy to resubmit your order, but otherwise it's best left as it is with an activation date of a week today.
16-02-2009 12:21 PM
16-02-2009 12:36 PM
This seems to be the norm, rather than the exception - certainly activations often occur the day before they are supposed to, and sometimes much earlier.
B.
16-02-2009 12:50 PM
Quote from: Barry Bear in mind that activations *often* occur early (in my case, on my latest account it occurred three days before it was supposed to, at 11pm on a Sunday evening!)
B.
I can only hope.
16-02-2009 6:51 PM
that said even with fast path on with o2 you would still most likely get high peak time pings due to too many customers and not enough bandwidth at most exchanges. o2 are even draging be there through the mud on the ping front by giveing 02 customers cheap broadband and piling them high
16-02-2009 9:18 PM
Either way, 120ms ping on O2 with Interleaving ON, with it OFF I'd get maybe 105ms? Pft.. There pathetic.
I really hope I get activated early.. i.e. Friday would be nice, like it stated it could..
jim:quote
17-02-2009 1:17 AM
be there must of said only if they keep the specailst side of the customer base ie offer fastpath ect.
18-02-2009 1:29 PM
Either way, hoping I get activated soon.. *cough* Friday.. )
20-02-2009 2:52 PM
23-02-2009 4:51 PM
I've just checked out your order and it's showing as being completed.
You should now be able to connect to us?
23-02-2009 11:45 PM
Although for a gaming package I'd of thought you'd of turned off Interleaving by default, oh well! I sent in a request to get it changed and within 5 minutes had been issued a reference number and was told it would be done within 24 hours, sweet.
Can't fault you so far.
adie:quote
24-02-2009 10:04 AM
However, with interleaving being off by default, there's a risk that you're first experience with us will be a dropping connection, which would be far from ideal
24-02-2009 5:34 PM
Maybe make it an option in the order process with "Interleaving: ON / OFF" then a help/question mark explaining the possible problems you may face by having it on and off and what it can do for you?
Not that it's too much hassle to have it on for a day and send a request in to have it turned OFF the next, although I'm sure you have some avid gamers here for the PC and consoles that don't know about Interleaving so can't research it and get better pings.
But I'm all sorted now.
adie:quote
24-02-2009 7:04 PM
I'm all for keeping the sign-up journey as simple as possible.
