Pro vs BBYW3
- Pro vs BBYW3
Pro vs BBYW3
27-10-2009 1:20 AM
So what are the pros and cons of moving from BBYW3 to Pro, apart from losing some 10GB in allowance? Can I remain on BBYW3 when my yearly contract runs out or will I be moved to Pro which is charged at almost the same price? I have a stable synch of 18272/1192 so am reluctant to change anything that might upset my line.
Message 1 of 4
(1,132 Views)
3 REPLIES 3
Re: Pro vs BBYW3
27-10-2009 1:27 AM
if your an ex trailist you can stay on your current package even thoe new customer and existing PN customers moving to adsl2+ cant use the legacy products on 21cn, am sticking with unlimited if and when the latency issue is sorted if not it will be more than a 21cn PN package upgrade i will be doing.
pro for PRO is line speed at all times lowest, prioity being the gold queue and con for PRO is as youve said you lose some usage allowence
Message 2 of 4
(408 Views)
Re: Pro vs BBYW3
27-10-2009 10:14 AM
Hi Dev,
You'll remain on your current product until you decide to change, if you do at all.
The main benefit from moving to Pro is that all traffic should run as fast as your line can handle, with no rate limits being applied to any protocols of Internet use.
Message 3 of 4
(408 Views)
Re: Pro vs BBYW3
27-10-2009 12:51 PM
Thanks James and Asbo
Message 4 of 4
(408 Views)
