Pro Add On with Unlimited
- Re: Pro Add On with Unlimited
15-01-2013 1:58 PM
I've seen lots of posts saying Pro is pointless on the new Unlimited packages, however I'm on a market 1 exchange and would want the 832kb/s upload speed. Do you get the 832kb/s upload speed on Unlimited or is Pro the only way to go?
Message 1 of 4
(725 Views)
3 REPLIES 3
15-01-2013 2:00 PM
Pro doesn't make any chance to your upload speed, that's the Max Premium service that costs £7.83 (IIRC) per month on a 20CN connection.
Message 2 of 4
(393 Views)
15-01-2013 2:02 PM
So to get the higher upload, I need the Max Premium, does that affect the way Unlimited works?
Message 3 of 4
(393 Views)
15-01-2013 2:02 PM
A misunderstanding
The pro addon which is being referred to only removes traffic shaping
The higher upstream speed is a different thing and is actually called Max Premium and can be added to the unlimited package here https://portal.plus.net/wizard/?wizard_id=20
However it is only of value if your exchange isn't 21CN enabled. If it is then the uncapped upstream gives the same thing and doesn't cost anything
EDIT - must type quicker
Message 4 of 4
(393 Views)
