Printing E mails in O E 6
- Printing E mails in O E 6
15-09-2008 7:01 PM
I am unable to print my messages in O E 6 the print tabs dont respond at all, This has worked in the past , so think I may have disabled something Any help apppreciated Thank You Ed
Message 1 of 8
(1,348 Views)
7 REPLIES 7
Re: Printing E mails in O E 6
15-09-2008 7:04 PM
Let's do this in a methodical fashion.
Is the printer plugged in and switched on?
Can you print from any other utilities on your computer?
Message 2 of 8
(623 Views)
15-09-2008 7:50 PM
Yes Yes Yes ,I can copy and paste the messages to Word, but no response if I click the printer picture at the top of an E mail or use file-print
Message 3 of 8
(623 Views)
15-09-2008 7:53 PM
What happens if you try Ctrl + P, or select PRINT from the file menu?
Message 4 of 8
(623 Views)
15-09-2008 7:59 PM
Nothing , but I can print my Yahoo mail (web mail)
Message 5 of 8
(623 Views)
15-09-2008 10:16 PM
I meant in Outlook Express.
Message 6 of 8
(623 Views)
15-09-2008 10:36 PM
I cant print in O E that is my problem, Also I have now found that my System Restore is completely blank, Thanks
Message 7 of 8
(623 Views)
16-09-2008 7:58 AM
In O E if I press Ctrl/ P a box comes up with script error, unable to remove this unless I close O E
Message 8 of 8
(623 Views)
