Postini Email Security Trial
- Postini Email Security Trial
Re: Postini Email Security Trial
21-11-2007 9:45 PM
21-11-2007 9:59 PM
Quote from: andyrogers When this trial starts, will the people who are on the trial have immediate access to the per user settings of the service or will this be introduced at a later date?
From Bob's blog post:
Quote The proposed timeline of events is as follows (some of which has already been done):
* Roll-out to internal mail platforms and implement subject line tagging
* Roll-out to staff broadband accounts minus subject line tagging
* Roll-out to trialists minus subject line tagging
* Introduce subject line tagging to trialists
* Roll-out to non-trialists complete with subject line tagging
* Roll-out per-user management to trialists
* Roll-out per-user management to non-trialists
21-11-2007 10:02 PM
Quote from: Dev Is there anything PN can do to stop labelling as spam mails between user1@mydomain.co.uk to user2@mydomain.co.uk? I am tired of forwarding these mails to despamchecker.
Try reading the service status posting!
http://usertools.plus.net/status/archive/1195665661.htm
(If you have not set yourself up to receive these by email you can do so here)
21-11-2007 11:15 PM
21-11-2007 11:37 PM
22-11-2007 4:28 PM
Quote from: andyrogers With this Postini trial, will any mail that has been blocked will it be held on the Postini service if say you are expecting an e-mail that has been incorrectly marked as spam and blocked?
No, not initially although further down the line (early next year?) we hope to offer Postini's quarantining service.
Quote Or will their be a way of checking a log to see what has been blocked just incase?
Again, not initially but this is where we hoping to head.
Quote When this trial starts, will the people who are on the trial have immediate access to the per user settings of the service or will this be introduced at a later date?
Introduced at a later date. To start with Postini will just be blocking the obvious stuff at the edge of the network. This means that you should receive *less* spam. The second step will be to activate subject line tagging which should hopefully then reduce the instances where spam gets through unmarked.
Quote from: jelv Will subscribing to the Postini trial reduce the number of genuine emails that are being lost at present (ticket 23446256)?
To begin with the Dspam processes will still be in place (it's Dspam that's is marking your mail incorrectly).
Further down the line though, we may well be able to do away with Dspam in its entirety. You should be aware of the work that got postponed this morning. Once this is rolled out you should see less occurrences of this. The changes will take a week or so to bed in though.
Take a look at my reply here. This should be fixed early next week.
22-11-2007 7:00 PM
Will the new postinis also sit between y SMTP server and the outside world?
In other words, doe SMTP users benefit from any spam reduction?
Oh, and is anyone else getting loads of Russian stuff? I can' read russian, but they seems to be advers for houses, tyres, and all sorts.
22-11-2007 9:40 PM
Quote from: Bob Introduced at a later date. To start with Postini will just be blocking the obvious stuff at the edge of the network. This means that you should receive *less* spam. The second step will be to activate subject line tagging which should hopefully then reduce the instances where spam gets through unmarked.
Could you explain "obvious stuff"? If it is to be blocked at the edge and not available for viewing (or in a log) then what is the chance of "obvious stuff" being ham?
22-11-2007 10:47 PM
What is the basis on which the Postini solution identifies SPAM?
It seems there is some degree of user control for the final rollout. What can be controled?
For customers who switch off SPAM filtering will ALL email be delivered? (and not have DNS re-directed to Postini) If not what will still be rejected?
23-11-2007 1:22 PM
Postini is the best!
My work uses the full postini service where each user has their own black/white lists and spam/blocked messages are held on the postini server for a few weeks.
SW.
3Mb FTTC
23-11-2007 5:58 PM
Quote from: GooKing Sorry if i'm being think....
Will the new postinis also sit between my SMTP server and the outside world?
No, those using smtp mail delivery or 3rd party mail exchanger records will not have their email proxied via Postini.
Quote from: atb Could you explain "obvious stuff"? If it is to be blocked at the edge and not available for viewing (or in a log) then what is the chance of "obvious stuff" being ham?
Judging by Postini's reporting and the findings from our internal trial the chance is nil
Email currently passes through a process called Clam that does this sort of thing at the moment.
I believe that customers will be able to request reports when we're able to roll-out the additional functionality early next year.
Quote from: MrToast For customers who switch off SPAM filtering will ALL email be delivered? (and not have DNS re-directed to Postini) If not what will still be rejected?
The 'edge' blocking will still be in effect, but the subject line tagging for the stuff that gets delivered will be switched off.
23-11-2007 6:19 PM
23-11-2007 8:09 PM
23-11-2007 8:14 PM
23-11-2007 8:50 PM
The privacy statement on the Postini website doesn't seem to include anything about data that they process for their End Users, other than the data obtained through their website.
As I am currently successful at avoiding spam I wouldn't be interested in using a third party scanning service and would prefer to avoid exposing all of my email through a single "external" body.
