Possible stuck profile
- Possible stuck profile
11-05-2009 9:16 AM
Re: Possible stuck profile
11-05-2009 9:55 AM
11-05-2009 10:02 AM
I've double checked and your Plusnet profile of 8000Kbps matches the BT IP Profile of 8000Kbps.
11-05-2009 12:41 PM
11-05-2009 12:45 PM
11-05-2009 4:08 PM
if you have xp then drtcp is needed but if your on vista this is automatic and it does make a gd job of it too
http://www.dslreports.com/drtcp
do the tweak tester and it will surrgest settings to enter into drtcp
22-05-2009 8:31 AM
22-05-2009 9:32 AM
22-05-2009 11:02 AM
22-05-2009 11:06 AM
ADSL & ADSL2+ are contended (shared) services. There is a finite amount of bandwidth available both at our end and at BTs end. Because it's shared, you may only get the full capabilities of your broadband connection when others are asleep, on other words, when there are less people using the service.
22-05-2009 11:39 AM
29-05-2009 10:21 AM
29-05-2009 10:34 AM
It could possibly help with some MTU & rWin tweaking though.
http://www.plus.net/support/broadband/troubleshooting/rwin_guide.shtml
Can you please try with an MTU of 1430 (on your router and your computer) and using a receive wiondow of 111200 and see if you notice an improvement. You will need to reboot your router and your computer after making these chanegs.
01-06-2009 10:38 AM
I looked at your recommendations above, but I am running Vista and DSLreports suggests that no changes should be/can be made. Would you agree or am I reading it wrongly? My BT/PN profile has dropped from 8000 to 7150 but my speedtester download speed remains in the 6530's which seems strange to me. I would have thought a drop in profile would also result in a drop in download speed?
My sync speed has remained at 9484 (other than a short drop to 4/5000 which soon self corrected) but profile has fallen from 8000 to 7150. Kitz site suggests that for a sync speed of 9484 that profile should be 8000. Why isn't mine?
01-06-2009 10:42 AM
Bt say that they saw a sync speed of 8192Kbps yesterday, hence why the profile has remained at 7150Kbps.
Hopefully it should pick up in a few days if you're getting the higher speed currently.
