Possible speed problem?
- Re: Possible speed problem?
23-12-2009 12:13 PM
23-12-2009 12:22 PM
On the BT tester did it say that the ipProfile was 2000 if so it is still in the 10 day training period and should sort itself out
23-12-2009 12:33 PM
I cant believe how quickly Plusnet managed to get my line sorted because of all the problems i had with Sky not giving me a MAC. Sky turned me off on the Friday and Plusnet had the router out to me and all working by Wednesday. I was looking at not having any internet over Christmas but someone at Plusnet must have worked overtime to get me up and running.
23-12-2009 12:49 PM
28-12-2009 6:17 PM
28-12-2009 6:26 PM
28-12-2009 7:51 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
1877 Kbps
0 Kbps 2000 Kbps
Max Achievable Speed
Download speedachieved during the test was - 1877 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :8128 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
If you wish to discuss these results please contact your ISP.
It seems to be running at the top of the range thats available at least.
28-12-2009 8:07 PM
28-12-2009 8:23 PM
28-12-2009 9:36 PM
29-12-2009 4:51 PM
02-01-2010 4:16 PM
Download speedachieved during the test was - 5324 Kbps
IP Profile for your line is - 7150 Kbps
06-01-2010 10:16 AM
