Portal password fault
- Re: Portal password fault
03-04-2008 4:05 PM
Is there a general fault with the portal. My password has stopped working to access the Members Centre. I would think it's me but I know someone else who can't get in either.
Message 1 of 3
(914 Views)
2 REPLIES 2
03-04-2008 4:17 PM
I've just checked and mine seems to be working absolutely fine.
Would you be able to manually delete your temporary internet files that relate to the portal to see if this helps?
Message 2 of 3
(374 Views)
03-04-2008 4:34 PM
Yep that fixed it. Not sure what happened, but good old clear everything and start again worked a treat.
Message 3 of 3
(374 Views)
