Portal Branding bug - in domain transfer tool
xpcomputers
Wasn't sure where to post this, but figured here was reasonable (but not perfect!)
On the Portal in the "Domain Admin" section, on the "Transfer in" page, it asks you for the
"Admin contact email:"
which defaults to:
"postmaster@<username>.plus.com"
Yet this is logged in to a Force9 account!!! I suspect that this is a remaining bug from the Portal harmonisation project.
Presumably this should default to:
"postmaster@<username>.<brandingurl>"
Hope this helps
Mike
2 REPLIES 2
Colin
Re: Portal Branding bug - in domain transfer tool
I'll get a problem raised on this when I've confirmed it.
Raised as 49698
xpcomputers
Thanks Colin,
Fortunately I noticed it when using the form, as my username wasn't too long, but if someone has a longer username, they might not see that it is wrong, and might submit it assuming that the default is correct.
Mike
