Port Forwarding
- Port Forwarding
Port Forwarding
08-04-2009 5:14 PM
I have the Thomson Gateway TG585 v7 router. On a previous router / connection I had to manually open required ports. Is this necessary / possible on this router? If so how is it done?
Message 1 of 4
(1,103 Views)
3 REPLIES 3
Re: Port Forwarding
08-04-2009 8:10 PM
uPnP should take care of your port forwarding but if you have trouble with certain apps then setting a forward rule up may be needed.
this may help but dont know if the v7(PN firmware) is diffrent http://portforward.com/english/routers/port_forwarding/Thomson-Alcatel/SpeedTouch585/Xbox_Live_360.h...
Message 2 of 4
(380 Views)
Re: Port Forwarding
09-04-2009 1:15 AM
Quote from: ASBO uPnP should take care of your port forwarding but if you have trouble with certain apps then setting a forward rule up may be needed.
Thanks for your response However, I don't know what uPnP is. Does this mean it just all takes care of itself?
Message 3 of 4
(380 Views)
Re: Port Forwarding
09-04-2009 2:33 AM
universal plug and play (upnp). yep pretty much takes care of its self but there is some instances where you may have to set a rule up manually.
if you log in to your router and have look thorough the menus you should find upnp and the menu to manual port forward.
If the link i gave you is not the same as the v7 firmware maybe some helpful soul who has a v7 will reply with a how to and some screen shots
Message 4 of 4
(380 Views)
