Port Forward Foscam IP Cam with Plusnet 2704n Router
- Re: Port Forward Foscam IP Cam with Plusnet 2704n ...
29-12-2015 9:48 AM
Can anybody explain how to setup an IP camera with the Port Foward menu?
It doesn't appear that any cameras are listed in the pre-defined Games/Application drop-down list.
Any help appreciated,
Thanks,
Howard
Thanks,
Howard
Message 1 of 2
(1,061 Views)
1 REPLY 1
Re: Port Forward Foscam IP Cam with Plusnet 2704n Router
29-12-2015 10:52 AM
I made this short guide about doing port forwarding for Xbox, just replace the ports I used here with the ones you need for the cameras
http://community.plus.net/forum/index.php/topic,147117.msg1294995.html#msg1294995
Message 2 of 2
(753 Views)
