Poor throughput
chrisyoung
Poor throughput
hi i have a similar problem but not my sync speed my atual through put. check this out-
Test1 comprises of Best Effort Test:  -provides background information.
    Your DSL connection rate: 10151 kbps(DOWN-STREAM),  1084 kbps(UP-STREAM)
    IP profile for your line is - 7150 kbps
    Actual IP throughput achieved during the test was - 285 kbps
11 REPLIES 11
James
Re: Poor synch after reconnect
Quote from: ctech500
My understanding is any tickets raised under ADSL2+(21CN)  are escalated to the comms team so they may take a little longer to get actioned.
(I could be wrong however)
They kept that quiet Wink
ADSL2+ faults are raised to our faults team, where we have dedicated ADSL2+ resource.
@chrisyoung
Ignore the throughput results on the BT Speedtester.  There's a 99.9% chance it's wrong.
chrisyoung
Re: I ( use to ) want to quit trial
yeah latency looking good now. tested around 9pm last night. but now have another problem with my bandwidth check out this-
James
That's not a problem with your bandwidth.
It's a known issue with the BT Speedtester being particularly useless.
chrisyoung
its the same through mybroadbandspeed.com
James
Mind showing me a speed test from there?
chrisyoung
mybroadbandspeed.com is the same
Fixes: 1,483
Re: Poor throughput
[Moderator's note by Adie (Adiewoo) posts split and merged from 2 topics.]
chrisyoung
chrisyoung
Re: Poor throughput
James
Ok - Not fantastic.
Can you reboot your router and retest?
chrisyoung
Re: Poor throughput
rebooted the router looks ok now strange!
