Poor ping performance this evening
- Poor ping performance this evening
03-06-2013 9:55 PM
Anyone else suffering this evening? I am on EANCC exchange.
Edit: here is the night before, quite a difference.
Re: Poor ping performance this evening
04-06-2013 11:15 AM
04-06-2013 11:31 AM
The initial default setting is 78Mbps but the maximum BT profile IIRC is 77.4 (ish), probably not but could a slight mis-match cause your packet loss?
I know when my Plusnet line speed was higher than my BT profile for a short while I was seeing a (very small but existent) packet loss on my TBB graph.
04-06-2013 11:58 AM
It was definitely different last night to what I had seen every evening of the month before. If it is like that again tonight I'd be tempted to gateway hop, but Kelly mentioned that makes it hard for you to debug as the gateway session is then gone and you can't trace it back to a node?
Could this also represent contention at the exchange?
04-06-2013 12:08 PM
Perhaps PN can set your 'Current line speed' to 77.4 (I think they round down to nearest 0.1).
04-06-2013 12:31 PM
04-06-2013 1:40 PM
The plusnet IP profile being 78 and you BT IP profile being 77.44 wouldn't cause packet loss, and if it did it wouldn't be only from 8pm to 11.30pm (Peak time) The yellow spiking with some blue underneath( Jitter) seems quite common place,during these hours if you look at other plusnet customers Ping graphs, although it varies across the plusnet gateways, Your graph is the 1st Plusnet Graph I've seen with low level packet loss at the same time as the jitter , and even the green(base latency) was beginning to increase too, where you downloading at the time ?
Quote from: jimbof My connection info is the same as yours (77.44 BT / 78 plusnet) though I had though that perhaps it was a rounding error on the plusnet webpage - why would they ever set a profile higher than the maximum BT profile? Has yours lowered now? Mine has remained the same in the month since installation.
It looks similar to what congestion would look like, the only difference being that the base latency isn't also elevated, Which may mean something else is responsible, ideally the yellow spikes shouldn't be present at all My Entanet Based connection Displayed similar issue during office hours (BE wholesale) which was their peak time,
04-06-2013 1:46 PM
Ex-Broadband Service Manager
04-06-2013 2:20 PM
This does beg the question - if it is the case that the plusnet "line speed" has to be less than the BT profile, then why do plusnet ever set a value of 78? As 77.44 is the maximum BT profile as far as I am aware... (80*0.9679=77.432)
I am not the only person with the profiles set as above - I know of at least one other forum member with 77.44 (BT) and 78 (plusnet)
04-06-2013 2:53 PM
Quote from: deathtrap where you downloading at the time ?
Other than any auto updates that might have downloaded, no. Late in the evening I started BBC streaming (SD), and crashplan was uploading at a fairly constant 4Mb/sec.
It is the first time in a month I've seen the graph do this (packet loss + such obvious blue&yellow steps) - and I've given the connection a much harder time in the past with no such phenomenon seen.
04-06-2013 2:59 PM
Quote from: jimbof This does beg the question - if it is the case that the plusnet "line speed" has to be less than the BT profile, then why do plusnet ever set a value of 78? As 77.44 is the maximum BT profile as far as I am aware... (80*0.9679=77.432)
It's wrong. We should be setting it at 77400. Dave is looking at how we prevent it being set at 78000.
04-06-2013 3:06 PM
So what is the next step on that matter then of incorrect line speed at plusnet - wait for the global fix or can it manually be set to the correct speed? If it is set manually, will it revert to 78 eventually?
Does it only affect people lucky enough to have a 77.44 BT profile, or is everyone's profile a bit too high?
04-06-2013 3:08 PM
I've manually adjusted yours to be correct.
I'm not convinced this caused those little latency spikes though. There is nothing wrong with the gateway I can see though. It could be exchange side of course.
04-06-2013 3:33 PM
I'll see what tonight is like.
04-06-2013 3:43 PM
