Poor WiFi on the TG582n?
- Poor WiFi on the TG582n?
06-06-2013 2:09 PM
Just curious to see if anyone else has been having issues with poor WiFi?
It seems to me that the signal indicator is showing 4-5 bars though I cant load any webpages!
Wish Plusnet would roll out some newer routers to cope with thicker walls and maintain a decent connection
..... or do Plusnet supply any other router?
Cheers all!
Connor
Re: Poor WiFi on the TG582n?
06-06-2013 2:23 PM
06-06-2013 2:35 PM
Still a lot better than my previous Netgear DGN1000!
Hopefully Plusnet will invest in something like this; http://www.amazon.co.uk/gp/product/B008NUOEA6/ref=as_li_qf_sp_asin_il_tl?ie=UTF8&camp=1634&creative=...
Thanks for the reply!
Connor
dick:quote
06-06-2013 2:44 PM
06-06-2013 2:51 PM
06-06-2013 7:04 PM
Quote from: Chris If you've got 4 or 5 bars, then that's not a poor signal?
True; Although how can I load webpages in one room but not in the other? Through a wall? The signal shows these bars although fails on loading anything.
Quote from: bradw Signal itself can be good, however the throughput can be %*$^. I personally gave up on the built-in wifi on first day. I highly doubt it can ever achieve better throughput than most people's FTT* connection which does make it somewhat useless.
^ Exactly my issue..
I now have a router spitting out 70+Mbps but cant do anything with it in the other room:')
Connor
07-06-2013 9:44 AM
07-06-2013 4:25 PM
dick:quote
07-06-2013 4:36 PM
If you can get hold of one a HH3 is a good router. I use a Netgear N300 and others recommend Asus' but they are quite expensive.
07-06-2013 7:01 PM
dick:quote
07-06-2013 7:31 PM
07-06-2013 8:13 PM
Thanks all,
Connor
