Poor VoIP / Slow Speeds - Stats Check
- Poor VoIP / Slow Speeds - Stats Check
Re: Poor VoIP / Slow Speeds - Stats Check
18-08-2013 7:39 PM
Ping statistics for 212.159.9.2:
Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 36ms, Maximum = 239ms, Average = 54ms
Will keep an eye on it.
19-08-2013 3:02 PM
20-08-2013 9:33 AM
We've updated your ticket with further details.
20-08-2013 4:32 PM
Did a quick TBB monitor to check, though lost that when the line dropped.
Packets: Sent = 100, Received = 94, Lost = 6 (6% loss),
Minimum = 39ms, Maximum = 132ms, Average = 45ms
Despite the tweaks DLM seems to be obsessed with breaking the line.
Should I give it 7 more days making it 10 since profile reset in the hope that DLM manages to stabilise things?
20-08-2013 4:53 PM
20-08-2013 8:39 PM
A quick check shows it wasn't just an isolated burst. Notice jitter is low so the line isn't heavily utilised when the test is done, just lossy
Detail for Test #1564076
Summary
This report refers to a connection test carried out by IP address 87.115.x.xxx on 20 Aug 2013 20:34:40 GMT+01:00.
Upstream jitter 1.1 ms
Downstream jitter 0.2 ms
Upstream packet loss 0.0 %
Downstream packet loss 9.1 %
Upstream packet order 100.0 %
Downstream packet order 91.6 %
Packet discards 0.4 %
MOS 1.0
REGISTER ms 560 ms
INVITE ms 563 ms
BYE ms 320 ms
Test Voice-over-IP
21-08-2013 10:17 AM
The spikes in maximum and average are due to the line being pretty trivial to near-saturate.
Uptime: 0 days, 12:34:09
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 675 / 2.163
Line Attenuation (Up/Down) [dB]: 39,0 / 66,5
SN Margin (Up/Down) [dB]: 5,5 / 5,9
Loss of Link (Remote): -
Error Seconds (Local/Remote): 3.067 / 0
FEC Errors (Up/Down): 2.949 / 82.479
CRC Errors (Up/Down): 169 / 103.462
HEC Errors (Up/Down): 587 / 26.440
22-08-2013 10:12 PM
Thanks for all the help so far.
At the moment the ticket is on hold until the 27th for the DLM run to complete. Not ideal, it's pretty poor and worked something like properly for 2 or 3 days since install on 22nd of July.
The loss is still there; a download from na3.salesforce.com showed it up quite badly - nearly an hour to download 195MB.
If after this it's still not working properly what's the next step? Is there one?
23-08-2013 11:56 AM
Irrelevant stuff removed from copy/paste.
Uptime: 0 days, 1:47:39
Bandwidth (Up/Down) [kbps/kbps]: 160 / 2.103
Output Power (Up/Down) [dBm]: 12,1 / 0,0
Line Attenuation (Up/Down) [dB]: 39,2 / 67,0
SN Margin (Up/Down) [dB]: 6,6 / 6,3
FEC Errors (Up/Down): 677 / 19.717
CRC Errors (Up/Down): 139 / 14.668
HEC Errors (Up/Down): 100 / 8.550
It's had a week, if anything things are now worse. Add to that just found some incorrect call charges and...
23-08-2013 4:39 PM
Regarding your call charges, I'd suggest putting the information in a ticket and we'll take a look at that.
27-08-2013 11:21 AM
This matches the previous weekend when the issue resolved on the Friday evening, however it returned on the Monday.
This time around that hasn't happened.
I will keep an eye on it, however it looks as though there is a source of noise which is constant throughout the week and goes away at the weekend. This source of noise was not present during the Bank Holiday and has not returned yet today.
if it does return I'll let you know, as the noise source is/was likely affecting many BT Wholesale customers. Hopefully a fault raised by someone else, perhaps the person whose line was carrying the noise in, has caused it to be resolved.
27-08-2013 5:13 PM
27-08-2013 9:28 PM
It's just resynched twice in quick succession on me now and the last resync has come back with this:
Uptime: 0 days, 0:01:15
Bandwidth (Up/Down) [kbps/kbps]: 221 / 1.888
Data Transferred (Sent/Received) [MB/GB]: 140,24 / 1,99
Output Power (Up/Down) [dBm]: 12,3 / 0,0
Line Attenuation (Up/Down) [dB]: 39,2 / 68,5
SN Margin (Up/Down) [dB]: 13,1 / 6,2
FEC Errors (Up/Down): 907 / 6
CRC Errors (Up/Down): 102 / 0
HEC Errors (Up/Down): 150 / 0
This appears to be a repetition of the earlier upstream instability fault that BT Wholesale reset a line card to resolve and claimed had been fixed. After of course initially claiming that there was no fault.
Not entirely sure VoIP is going to work too well with this:
Test Type: Voice over IP
Downstream Jitter: 43.3 ms
Downstream Loss: 0 %
Downstream Packet Order: 100 %
Upstream Jitter: 12.21 ms
Upstream Loss: 4.8 %
Upstream Packet Order: 100 %
Packet Discards: 3.36 %
MOS Score: 1.1
27-08-2013 9:36 PM
Uptime: 0 days, 0:00:52
Bandwidth (Up/Down) [kbps/kbps]: 49 / 2.130
Yes that's 49 kilobits per second.
I'm going to have to reset the connection to try and get an upload speed high enough to use the connection to any degree.
28-08-2013 9:57 AM
