Poor Speeds, SNR and Router dropping out!
- Poor Speeds, SNR and Router dropping out!
06-07-2011 9:54 PM
Re: Poor Speeds, SNR and Router dropping out!
07-07-2011 10:14 AM
Your latest connection has been ongoing for over 18 hours, the one before that was over 19 days so it looks like the account attached to your forum username is working fine. It may well be a reporting blip rather than any loss of connectivity if this is the account you're talking about?
07-07-2011 11:04 AM
07-07-2011 11:13 AM
Are you using LAN or wireless?
07-07-2011 11:22 AM
07-07-2011 4:57 PM
07-07-2011 6:03 PM
07-07-2011 6:39 PM
Can you post the DSL diagnostics info from the 2700 , that might give more information as to any drops.
If its a v5 firmware its here :- http://home/xslt?PAGE=J42&THISPAGE=A02_POST&NEXTPAGE=J42 , not sure where it is on a v6 firmware I'm afraid.
07-07-2011 6:59 PM
07-07-2011 7:34 PM
I think these 'drops' are nothing more than RouterStats being unable to get a sample from the router so it reports 'zero'. The usual cause of that is the router being busy, but difficulty receiving pages at the same time suggests problems with the connection from your PC
Having said this, your noise margin is significantly above the normal target value of 6dB. Disconnections or high error counts in the past could have caused the DLM to increase your target noise margin perhaps to 15dB. That would account for most of the drop in sync speed you mention. Were you having connection problems around the time your sync speed started its downward spiral?
07-07-2011 8:12 PM
There is something on those diagnostics that's troubling though the 'Suspicious Impulse Noise detected', that's quite often a result of a failing microfilter. Have you got another one you could try ?
07-07-2011 10:02 PM
MisterW, I just changed over both the microfilters, and on the diagnostics page the Suspicious Impulse Noise has now cleared down. Would it be worth trying to force my DSL into learning mode? Again I thank you both for your help.
08-07-2011 11:56 AM
If Plusnet are willing to do a reset on your line that should increase your sync speed - and transfer speeds once the DLM catches up and increases your IP Profile. However power cuts could cause the problem to return.
08-07-2011 4:47 PM
dick:quote
08-07-2011 5:53 PM
