Poor DL speed
- Poor DL speed
Poor DL speed
18-11-2010 11:43 PM
Re: Poor DL speed
18-11-2010 11:48 PM
1. Results from a BT Speed test
2. What https://portal.plus.net/my.html?action=stable_rate says for your current line speed
3. The stats reported by your router (sync speed, attenuation and noise margin)
Re: Poor DL speed
19-11-2010 7:56 AM
DSL Connection
Link Information
Uptime: 49 days, 21:33:21
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 467 / 9,727
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 42.00
Output Power (Up/Down) [dBm]: 13.0 / 0.0
Line Attenuation (Up/Down) [dB]: 18.5 / 36.0
SN Margin (Up/Down) [dB]: 14.5 / 8.5
Loss of Framing (Local/Remote): 1,622 / 0
Loss of Signal (Local/Remote): 160 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 509 / 0
FEC Errors (Up/Down): NA / 0
CRC Errors (Up/Down): NA / 268,958
HEC Errors (Up/Down): 0 / 215,487
BT Speed Test taken 15mins ago:
Download speed achieved during the test was - 6205 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
IP Profile for your line is - 8000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 10.92:22.17:66.92 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
Telephone number:
01723XXXXXX
Phone exchange:
SCARBOROUGH
Estimated line speed:
8 - Checked on 2010-05-15 17:11:11
Current line speed:
8000
Re: Poor DL speed
19-11-2010 9:56 AM
Is your telephone line crystal clear or have you noticed any decline in that?
I'd like to see the router stats after you have done ONE router reboot between 10am and 2pm, I think there's a good chance that you will then see (and hold) a faster sync speed.
Re: Poor DL speed
19-11-2010 4:13 PM
Re: Poor DL speed
19-11-2010 5:11 PM
The reason you can't sync higher than that is that the line is banded (4M-9M) I am now asking for this to be removed to see what happens. I will come back to you here when I find out more information.
Jojo
Re: Poor DL speed
20-11-2010 9:25 AM
Re: Poor DL speed
20-11-2010 11:46 AM
Re: Poor DL speed
20-11-2010 11:46 AM
Re: Poor DL speed
20-11-2010 8:47 PM
Re: Poor DL speed
21-11-2010 12:56 PM
Re: Poor DL speed
21-11-2010 1:03 PM
the banding has now been lifted, just have to wait for the DLM to lift the profile at BT side.
Jojo
Re: Poor DL speed
21-11-2010 1:54 PM
Re: Poor DL speed
21-11-2010 5:19 PM
I'll keep an eye on it for you and if if lifts I'll make sure our profile macthes it.
Jojo
Re: Poor DL speed
22-11-2010 8:23 PM
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
6892 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 6892 Kbps
For your connection, the acceptable range of speedsis 2000-7150 Kbps.
The throughput of Best Efforts (BE) classes achieved during the test is - 21.24:20.17:58.59 (SBE:NBE:PBE)
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
Router sats
DSL Connection
Link Information
Uptime: 3 days, 2:20:15
Bandwidth (Up/Down) [kbps/kbps]: 1,123 / 11,023
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 2.00
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 18.5 / 35.5
SN Margin (Up/Down) [dB]: 6.5 / 5.0
Loss of Framing (Local/Remote): 1,633 / 0
Loss of Signal (Local/Remote): 161 / 0
Error Seconds (Local/Remote): 516 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 14,326
HEC Errors (Up/Down): 0 / 9,624
Heres hoping and waiting
