Plusnet time server down
nw71
The Plusnet time server seems to be down.
This can cause a problem if like me you use your router to schedule internet services to individual devices on you network e.g. setting access control times for kid's iPads / phones etc or to schedule timing for the whole of your wireless network
The server at ntp.plus.net is not working therefore the time control features of the router will fail
In order to restore the access control you need to enter another time server such as 0.uk.pool.ntp.org (you can add up to 6)
Hope this is useful - my kids were up late browsing last night and were a nightmare to get out of bed and up for school this morning!Shocked
23 REPLIES 23
RichardB
Seasoned Champion
Fixes: 39
Re: Plusnet time server down
Hi nw71,
Which PN NTP server are you using?
I am using 212.159.6.10 in my router to synch the time and it seems to be OK currently.
Richard
nw71
My router is a Technicolor TG582n FTTC and was set to use ntp.plus.net - i don't know the ip address
I have never had a problem with it for the two years we've had it but it has been failing to sync for the last two days
I have tried several different ntp servers eg
ntp2a.mcc.ac.uk
ntp.exnet.com
0.uk.pool.ntp.org
and they all work fine, just not the plusnet one (maybe it's local to lancashire?)
Cheers,
Neil
RichardB
Seasoned Champion
Fixes: 39
As a test I installed the clock synch app on my android phone.
Set the NTP server to ntp.plus.net and it worked time was displayed correctly with no errors reported.
To double check I set the ntp server to ntp.plus.not and the app reported that the server could not be found.
Not sure if it is a conclusive test but ntp.plus.net seems to work for me.
Richard
Browni
Aspiring Hero
Fixes: 60
I use ntp.plus.net as a ping target for a speed tester I run and I haven't seen any outages recently.
Fixes: 1,600
I've checked with our network team and I can confirm that our NTP servers are working correctly.
ejs
Aspiring Hero
Fixes: 25
It appears I haven't been able to access the NTP service on ntp.plus.net since July 7 also.
Perhaps the NTP servers themselves may be running fine, but some customers can't access that service on them?
ntp.plus.net resolves to the same 4 IP addresses as the DNS servers, pinging them and DNS services still work.
seebee
Fixes: 9
Plusnet time servers don't seem to be working for me either:
pi@rPi3:~ $ ntpdate -d ntp.plus.net
 8 Jul 18:55:35 ntpdate[20172]: ntpdate 4.2.6p5@1.2349-o Mon Jul 25 22:35:35 UTC 2016 (1)
transmit(212.159.6.9)
transmit(212.159.6.10)
transmit(212.159.13.50)
transmit(212.159.13.49)
212.159.6.9: Server dropped: no data
212.159.6.10: Server dropped: no data
212.159.13.50: Server dropped: no data
212.159.13.49: Server dropped: no data
server 212.159.6.9, port 123
stratum 0, precision 0, leap 00, trust 000
refid [212.159.6.9], delay 0.00000, dispersion 64.00000
transmitted 4, in filter 4
reference time:    00000000.00000000  Thu, Feb  7 2036  6:28:16.000
originate timestamp: 00000000.00000000  Thu, Feb  7 2036  6:28:16.000
transmit timestamp:  dd0b9b1e.11043c0b  Sat, Jul  8 2017 18:55:42.066
filter delay:  0.00000  0.00000  0.00000  0.00000
filter offset: 0.000000 0.000000 0.000000 0.000000
offset 0.000000
server 212.159.6.10, port 123
refid [212.159.6.10], delay 0.00000, dispersion 64.00000
transmit timestamp:  dd0b9b1e.443da488  Sat, Jul  8 2017 18:55:42.266
offset 0.000000
server 212.159.13.50, port 123
refid [212.159.13.50], delay 0.00000, dispersion 64.00000
transmit timestamp:  dd0b9b1e.77627d38  Sat, Jul  8 2017 18:55:42.466
offset 0.000000
server 212.159.13.49, port 123
refid [212.159.13.49], delay 0.00000, dispersion 64.00000
transmit timestamp:  dd0b9b1e.aa945d37  Sat, Jul  8 2017 18:55:42.666
offset 0.000000
 8 Jul 18:55:44 ntpdate[20172]: no server suitable for synchronization found
Whilst other NTP servers are okay:
pi@rPi3:~ $ ntpdate -d uk.pool.ntp.org
 8 Jul 18:56:58 ntpdate[20174]: ntpdate 4.2.6p5@1.2349-o Mon Jul 25 22:35:35 UTC 2016 (1)
transmit(176.58.109.199)
receive(176.58.109.199)
transmit(129.250.35.250)
receive(129.250.35.250)
transmit(85.199.214.101)
receive(85.199.214.101)
transmit(185.114.227.160)
receive(185.114.227.160)
server 176.58.109.199, port 123
stratum 2, precision -22, leap 00, trust 000
refid [176.58.109.199], delay 0.03864, dispersion 8.00011
reference time:    dd0b9770.47a5faaf  Sat, Jul  8 2017 18:40:00.279
originate timestamp: dd0b9b70.bd112f34  Sat, Jul  8 2017 18:57:04.738
transmit timestamp:  dd0b9b70.bb2c836b  Sat, Jul  8 2017 18:57:04.731
filter delay:  0.03871  0.00000  0.04074  0.03864
filter offset: 0.000781 0.000000 0.000543 0.000865
offset 0.000865
server 129.250.35.250, port 123
stratum 2, precision -20, leap 00, trust 000
refid [129.250.35.250], delay 0.03790, dispersion 0.00023
reference time:    dd0b9b5a.2451c9b1  Sat, Jul  8 2017 18:56:42.141
originate timestamp: dd0b9b70.f0438d08  Sat, Jul  8 2017 18:57:04.938
transmit timestamp:  dd0b9b70.ee5d4f48  Sat, Jul  8 2017 18:57:04.931
filter delay:  0.03809  0.03802  0.03790  0.03824
filter offset: 0.000957 0.001073 0.000760 0.001098
offset 0.000760
server 85.199.214.101, port 123
stratum 1, precision -25, leap 00, trust 000
refid [GPS], delay 0.03929, dispersion 0.00012
reference time:    dd0b9b71.00000000  Sat, Jul  8 2017 18:57:05.000
originate timestamp: dd0b9b71.238ee1bd  Sat, Jul  8 2017 18:57:05.138
transmit timestamp:  dd0b9b71.218eb253  Sat, Jul  8 2017 18:57:05.131
filter delay:  0.03943  0.03929  0.04060  0.03955
filter offset: 0.000734 0.000878 0.000340 0.000841
offset 0.000878
server 185.114.227.160, port 123
refid [185.114.227.160], delay 0.04491, dispersion 56.00000
reference time:    dd0b9849.259454b3  Sat, Jul  8 2017 18:43:37.146
originate timestamp: dd0b9b6d.574b4ebe  Sat, Jul  8 2017 18:57:01.340
transmit timestamp:  dd0b9b71.54c04109  Sat, Jul  8 2017 18:57:05.331
filter delay:  0.00000  0.04491  0.00000  0.00000
filter offset: 0.000000 0.000121 0.000000 0.000000
offset 0.000121
 8 Jul 18:57:07 ntpdate[20174]: adjust time server 85.199.214.101 offset 0.000878 sec
The Plusnet time servers are replying to pings okay:
pi@rPi3:~ $ ping -c 5 ntp.plus.net
PING ntp.plus.net (212.159.6.9) 56(84) bytes of data.
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=1 ttl=60 time=11.5 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=2 ttl=60 time=11.1 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=3 ttl=60 time=21.4 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=4 ttl=60 time=14.9 ms
64 bytes from cdns01.plus.net (212.159.6.9): icmp_seq=5 ttl=60 time=11.2 ms
--- ntp.plus.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4005ms
rtt min/avg/max/mdev = 11.198/14.061/21.412/3.943 ms
PING ntp.plus.net (212.159.13.49) 56(84) bytes of data.
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=1 ttl=60 time=10.4 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=2 ttl=60 time=13.0 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=3 ttl=60 time=13.3 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=4 ttl=60 time=11.1 ms
64 bytes from cdns01.plus.net (212.159.13.49): icmp_seq=5 ttl=60 time=10.8 ms
rtt min/avg/max/mdev = 10.473/11.781/13.371/1.187 ms
This is all on a Raspberry PI, but I've also tried using it as a time server in windows 10 and it doesn't respond then either.
Perhaps it depends on the source IP which is why others dont see a problem. My Plusnet IP is currently 51.9.132.x but I also tried from a Debian machine in America (from IP 199.175.48.x) and got exactly the same - ntp.plus.net is not replying to NTP requests (but is replying to pings) whilst other NTP servers are replying okay.
Fixes: 160
Looks like different users are having different experiences. I'm on a fixed IP and still have full connectivity to the time servers. From my router log.
Jul 8 20:08:46 SNTP Synchronised to server: 212.159.6.9
Info Jul 8 19:08:46 SNTP Synchronised to server: 212.159.13.50
Info Jul 8 18:08:46 SNTP Synchronised again to server: 212.159.6.10
I'm now wondering if gateways, new and old network connectivity have any bearing?
MauriceC
Resting Legend
Fixes: 17
Dredging my memory, there was a problem some years back (2010) with the plusnet Firewall defaulting to 'High' causing similar problems.  Tried a search but couldn't find a good reference.  As @Townman suggests has it resurfaced with the new network routing?
30FTTC06
Fixes: 4
No problems here, static ip 80.229....
6 Feb 02:28:56 ntpdate[3082]: ntpdate 4.2.8p10@1.3728-o Tue Apr 25 07:24:47 UTC 2017 (1)
Looking for host ntp.plus.net and service ntp
212.159.13.50 reversed to cdns02.plus.net
cdns02.plus.net forward check lookup fail: Name or service not known
host found : 212.159.13.50 (cdns02.plus.net)
receive(212.159.13.50)
receive(212.159.6.9)
receive(212.159.13.49)
receive(212.159.6.10)
stratum 2, precision -21, leap 00, trust 000
refid [212.159.13.50], delay 0.03918, dispersion 0.00000
reference time: dd0bc8c0.621b1036 Sat, Jul 8 2017 15:10:24.383
originate timestamp: dd0bcb60.657f54af Sat, Jul 8 2017 15:21:36.396
transmit timestamp: dc42c05f.0fb69985 Mon, Feb 6 2017 2:29:03.061
filter delay: 0.03929 0.03952 0.03918 0.03946
filter offset: 13175553 13175553 13175553 13175553
offset 13175553.328176
refid [212.159.6.9], delay 0.03903, dispersion 0.00000
reference time: dd0bc85b.6ecd6f45 Sat, Jul 8 2017 15:08:43.432
originate timestamp: dd0bcb60.98bd4ede Sat, Jul 8 2017 15:21:36.596
transmit timestamp: dc42c05f.42eafab5 Mon, Feb 6 2017 2:29:03.261
filter delay: 0.03903 0.03911 0.03931 0.03946
offset 13175553.328377
refid [212.159.13.49], delay 0.03918, dispersion 0.00000
originate timestamp: dd0bcb60.cbe2a0e5 Sat, Jul 8 2017 15:21:36.796
transmit timestamp: dc42c05f.761ec4e7 Mon, Feb 6 2017 2:29:03.461
filter delay: 0.03975 0.03922 0.03943 0.03918
offset 13175553.328215
refid [212.159.6.10], delay 0.03934, dispersion 0.00000
reference time: dd0bc5a3.259c646f Sat, Jul 8 2017 14:57:07.146
originate timestamp: dd0bcb60.ff10fbec Sat, Jul 8 2017 15:21:36.996
transmit timestamp: dc42c05f.a9513f8e Mon, Feb 6 2017 2:29:03.661
filter delay: 0.03949 0.03935 0.03934 0.03949
offset 13175553.328254
6 Feb 02:29:03 ntpdate[3082]: step time server 212.159.6.9 offset 13175553.3283 77 sec
ejs
Aspiring Hero
Fixes: 25
If the Plusnet Broadband Firewall had been set to "High", then each person affected wouldn't have been able to access any NTP services.
mort7890
Fixes: 4
Just looked into my plusnet hub one and the log shows
19:24:08, 23 Mar. (156261.950000) NTP synchronization failure!
When I look at plusnet access control the current time is "retrieving" and looks like it has been since the 22 Mar.
RichardB
Seasoned Champion
Fixes: 39
Hi all,
For info:
ntpdate -d ntp.plus.net works OK for me on my RPI. All servers responded.
However, I do have a static IP in the range of 80.229.x.x.
Currently connected to pcn-bng04 just in case it is relevant.
Richard
pvmb
Warning Jul 9 11:26:24 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 10:25:38 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 09:24:53 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 08:24:08 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 07:23:22 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 06:22:37 SNTP Unable to contact server: 212.159.6.9
Warning Jul 9 05:21:51 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 04:21:06 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 03:20:21 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 02:19:35 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 01:18:50 SNTP Unable to contact server: 212.159.13.50
Warning Jul 9 00:18:05 SNTP Unable to contact server: 212.159.13.50
Warning Jul 8 23:17:19 SNTP Unable to contact server: 212.159.13.50
Warning Jul 8 22:16:34 SNTP Unable to contact server: 212.159.13.50
Warning Jul 8 21:15:48 SNTP Unable to contact server: 212.159.13.50
Warning Jul 8 20:15:03 SNTP Unable to contact server: 212.159.6.9
Warning Jul 8 19:14:18 SNTP Unable to contact server: 212.159.13.49
Warning Jul 8 18:13:32 SNTP Unable to contact server: 212.159.6.10
Warning Jul 8 17:12:47 SNTP Unable to contact server: 212.159.6.9
Warning Jul 8 16:12:01 SNTP Unable to contact server: 212.159.6.10
Warning Jul 8 15:11:16 SNTP Unable to contact server: 212.159.6.10
Warning Jul 8 14:10:31 SNTP Unable to contact server: 212.159.6.10
Warning Jul 8 13:09:45 SNTP Unable to contact server: 212.159.6.9
Warning Jul 8 12:09:00 SNTP Unable to contact server: 212.159.6.10
Warning Jul 8 11:08:15 SNTP Unable to contact server: 212.159.13.49
