Plusnet chat server
jelv
Fixes: 10
Plusnet chat server
There is a Plusnet chat server which can be accessed via http://usertools.plus.net/irc/
However this a web interface and it doesn't seem to work in Firefox (I can connect but there is no box to type into).
Are there any instructions for using an IRC client - I've added ChatZilla to Firefox but can't figure how to get it working.
I'm sure it would be used far more if (a) people knew it existed and (b) there were instructions (server name etc)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
16 REPLIES 16
Fixes: 1,483
Re: Plusnet chat server
You can use any IRC client from within a PN connection
use /attach usertools.plus.net then /join #usertools within your client
James
You should just be able to tell chatzilla to connect to (server name) usertools.plus.net and channel #usertools
Or if you download an actual IRC client
/server usertools.plus.net
/join #usertools
jelv
Fixes: 10
Got in there - after I switched from RIN to the normal Plusnet centrals!
James
Ok, that's quite bizarre!
jelv
Fixes: 10
I think direct connection is limited to Plusnet IPs - obviously RIN never got added
Be3G
Quote from: jelv
I agree - back 'in the day' when Usertools was better promoted we did indeed get considerably more visitors. (Thanks for adding it to your signature by the way.)
Lurker
Quote from: jelv
Probably true, and unlikely to get high on the list since the trial technically ended some time ago!
Having said that though, I don't know whether MAAF Users, or those from Brightview etc would be able to access, presumably F9 and FOL are already added, along with MN.
Santiago
F9 worked for me
Lurker
I would have checked myself, but I finally closed my F9 and FOL accounts late last week. Sad
Fixes: 1,483
Not that you venture into it much anyway 😛
Lurker
Lies - I've been there twice, and both times Assos was mean. Tongue
Be3G
It's probably safe for you to pop in today then - he's not said a word all day (well, since I logged in anyway).
Fixes: 1,483
He's down the pub Wink
James
Assos is always down the pub.  And complaining about it!
