Plusnet assist update not working
grahamjohn
I had a Plusnet Assist pop up stating that XP, Vista and Windows 7 users have an important up date which I clicked. This opened Explorer with the message: This update requires elevation..and so on ..click Next. When I click next on my laptop (Vista) and my PC (7) nothing happens!
Please advise.  Undecided
Graham
17 REPLIES 17
Anotherone
Champion
Fixes: 21
Re: Plusnet assist update not working
Was the message referring to a Windows Update or a Plusnet Assist update?
w23
Fixes: 4
Just manually run Windows Update?
Then uninstall Plusnet Asist??  Wink
Call me 'w23'
grahamjohn
This is a Plusnet Assist update.
w23
Fixes: 4
If it's failing to update itsself then uninstall.
Re-install after if you find it useful (hopefully the reinstall will be the updated version).
Call me 'w23'
grahamjohn
Many thanks for the advice, I can re-install ok but as there is a problem with Plusnet Assist I will see if plusnet resolve it first. I have used Assist a few times and have found it to be very useful.
Pettitto
Fixes: 5
Did uninstalling and reinstalling Plusnet Assist resolve the issue for you?
The more information we can collate, we can then look into any issues that arise Smiley
w23
Fixes: 4
Quote from: grahamjohn
...there is a problem with Plusnet Assist...
Was there any problem other than failing to update?
Call me 'w23'
Aspiring Hero
Fixes: 73
You need to run the update as administrator.
Dan.
w23
Fixes: 4
@Dan, your eyes (or brain?) are better than mine!
Well spotted, especially if it turns out to be the solution!
Call me 'w23'
Aspiring Hero
Fixes: 73
@walker23
Hopefully it will, I've come across this problem a few times.
Dan.
grahamjohn
Thanks for all the advice so far. I know how to run Plusnet assist as and Adminstrator but I do not see how to run the update as one. A pop up appears which when clicked on opens IE with the option only to click next.
How will I know if I uninstall and re-install Plusnet Assist I have the new version or my original version?
Oldjim
Resting Legend
Fixes: 63
I suggest opening IE as Administrator - right click on shortcut and select Run as administrator - then try the update.
It should use the existing open application rather than starting a second one
Chris
Legend
Fixes: 169
I've asked our Plusnet Assist guru for any advice they might have on this too.
grahamjohn
Hi, I have uninstalled and reinstalled Plusnet Assist on my laptop. I am unable to tell if the version is the new one except for the date created is now today's date.
If I run IE as an administrator and open Plusnet Assist it gives me the Plusnet Assist home page online and there is no way to force the update that I can see.
Am I missing something here?
Thanks everyone.
