Plusnet access control.
Sophiee19
so i wanted to set a Time limit on my router so I searched on here for access control and clicked on the link 129 or something and disconnected my router... and now when I go to click on the link it dosent work, I cant now go back on the link as its not working to re connect my router... any suggestions?
3 REPLIES 3
Fixes: 419
Re: Plusnet access control.
@Sophiee19  Welcome to the forum.
It's difficult to help as we don't know which hub you have or what 'link 129' is.
If you've screwed up a Plusnet hub setting your best bet is to push a paperclip or similar into the reset hole which you will find on the hub and using that keep the switch closed for at least 25 seconds. If you then leave it alone it should set itself up again from scratch and reconnect you.
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My Router
Sophiee19
Thank for replying it was this link but now it dosent work http://192.168.1.254/index.cgi?active_page=9117&active_page_str=page_settings_b_parental&req_mode=1&... now I cant get back on it to.connect it
