Plusnet Speedtest
- Re: Plusnet Speedtest
Plusnet Speedtest
18-11-2014 8:52 AM
18-11-2014 8:54 AM
To be is to do - Kant
do be do be do - Sinatra
18-11-2014 8:58 AM
dick:quote
18-11-2014 9:04 AM
18-11-2014 9:14 AM
dick:quote
18-11-2014 9:18 AM
18-11-2014 9:33 AM
18-11-2014 2:50 PM
I don't know who or what I am replying to !
But yes that is the web site that I am trying to do the speed test with, but does not work for me so why does it work for some and not others ?
Come on Plusnet please get involved and help
18-11-2014 3:11 PM
Can you use any other similar speedtests such as speedtest.net ?
18-11-2014 7:17 PM
As I have said it used to work ok, and has just stopped working.
But what do you mean" so if it's not working at all for you then it's likely to be an issue local to yourself." (what do you mean issue locally) ?
Steve
18-11-2014 7:20 PM
18-11-2014 7:48 PM
think Broadband 24860 8270
Ookla 25060 7660
P Net 24951 7793
18-11-2014 7:57 PM
You can check that Flash is installed and working on your PC here:
http://helpx.adobe.com/flash-player.html
18-11-2014 8:16 PM
Slightly more sophisticated and requires Java http://myspeed.visualware.com/index.php
