Plusnet Pro Addon lower Throughput
- Re: Plusnet Pro Addon lower Throughput
18-01-2016 1:21 PM
Hi, I just recently upgraded to the pro add on about 12 hours or so I was getting 15+mb (15-15.5 using speedtest.net, TBB and bt speed tester) since I upgraded its been 14mb always 14mb. (wired) seems to be a case of slightly better ping (1-2 ms on my game which isn't on the list) or getting 1.5mb extra. I thought it wouldn't effect throughput and it may actually increase it in some circumstances but this has not been the case. I don't understand how this could change it as i thought it was just prioritisation (less dropped packets due to congestion etc).
Line stats as follows
5 - Mode ADSL
6 - Uptime: 0 days 00:28:44
7 - Data rate: 1279/17923
8 - Maximum data rate: 1288/18132
9 - Noise margin: 6.0/3.3
10 - Line attenuation: 16.4/29.0
12 - Data sent/received: 4.7M/81.7M
BTW
1. Best Effort Test:
Download Speed : 14.04 Mbps
2. Upstream Test:
Upload Speed : 1.09 Mbps
Current
TBB
Current
Rather disappointed at the moment considering its £5 a month extra for less speed and almost negligible improved ping.
I tried the further diagnostics on btw but i get this message "Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information."
I see no other reason for the speed decrease as my sync rate is marginally higher than it was ( i reset it today to see if it would improve speed) previous sync was slightly lower (negligible) 3 days sync and beofre that it was the same at 6 days sync.
Really confused and any help would be appreciated
5 - Mode ADSL
BTW
2. Upstream Test:
Current
TBB
Current
Message 1 of 5
(977 Views)
4 REPLIES 4
18-01-2016 2:17 PM
So I've done more tests by removing pro then re adding it and it has to be the pro add on
pro just removed
BTW
Download Speed : 14.89 Mbps
2. Upstream Test:
speed test.net
Pro Added
speed test
BTW 1. Best Effort Test:
Download Speed : 14.05 Mbps
2. Upstream Test:
Why is the pro apparently being artificially capped at 14mb for me? Kind of makes this "addon" totally pointless and a waste of £5
more confused than ever
pro just removed
BTW
2. Upstream Test:
speed test.net
Pro Added
speed test
2. Upstream Test:
Message 2 of 5
(656 Views)
18-01-2016 2:30 PM
If you are on an Unlimited package the Pro add-on on makes a difference when you are using the full capacity of the line and then it alters the relative priorities; it is therefore pretty pointless for most people and why Plusnet haven't removed it as an option for people on Unlimited accounts none of us can understand.
Be careful enabling/disabling - you may be charged multiple times!
Message 3 of 5
(656 Views)
18-01-2016 2:43 PM
So they're effectively selling a service that does nothing but slow down your connection? that baffles me to no end
Message 4 of 5
(656 Views)
18-01-2016 2:56 PM
Quote from: iruhaku that baffles me to no end
Join the club!
Message 5 of 5
(656 Views)
