Plusnet One Hub - Firmware firmware version: 4.7.5.1.83.8.237.2.2 - Watchdog resets
KTILBURY
Any hekp would be anticipated - when doing FTP backups on my website using FileZilla I and often experiencing my router rebooting itself and logging a ( 13.750000) Boot reason: watchdog reset (cause: 0x2) event in the error log.
Any ideas please!
5 REPLIES 5
Jubby
Fixes: 31
Re: Plusnet One Hub - Firmware firmware version: 4.7.5.1.83.8.237.2.2 - Watchdog resets
Hi @KTILBURY,
Sorry to hear you are experiencing drops when performing backups via FTP.
I have updated the automated system for your router, could you kindly factory reset the router and let us know how you get on.
Thank you.
 Lewis G
 Infrastructure Operations Professional
KTILBURY
Hi @Jubby
Thanks for your help - rebooted as requested bit still got this in Event log, and a reboot when I tried a FTP copy of the website
18:00:03, 24 Nov. ( 27.730000) System up, firmware version: 4.7.5.1.83.8.237.2.2
17:59:48, 24 Nov. ( 13.490000) System start
17:59:48, 24 Nov. ( 13.490000) Boot reason: watchdog reset (cause: 0x2)
So any further ideas whats causing the issue?
Many Thanks
Kathy
bobpullen
Fixes: 184
Did you fully factory reset the device by inserting something into the pinhole at the back until the status light flashes green?
Need to check that this has been done, rather than a simple reboot/restart, as next step is likely a replacement.
KTILBURY
Hi Bob,
No I just did a Power off reset - will do a factory one and report back!
Thanks for asking!
Kathy
KTILBURY
Hi there
Full factory reset redone - and had askcowlegement of firmware install.
Still have a
11:27:55, 27 Nov. ( 28.000000) System up, firmware version: 4.7.5.1.83.8.237.2.2
11:27:40, 27 Nov. ( 13.450000) System start
11:27:40, 27 Nov. ( 13.450000) Boot reason: watchdog reset (cause: 0x2)
reported This morning when doing a FTP back up!
Let me know next step! Thanks
Kathy
