Plusnet Line Speed lower than BT IP Profile
robski1
Fixes: 7
After having  a stable connection for many weeks, I had several disconnects yesterday whilst BT were doing some work outside of my house.
All is stable now and my BT IP Profile has climbed back to 12.83 Mbps but my PlusNet Line speed seems to be stuck at 11.5 Mbps.
Could someone at PlusNet give it a tweak for me. Wink
Thanks, robski1
7 REPLIES 7
bobpullen
Fixes: 316
Re: Plusnet Line Speed lower than BT IP Profile
Done. You may need to disconnect/reconnect if the automated script doesn't kick you within the next hour or so.
shure
this may sound like a dumb question but are you expected to get the full profile speed then?  My Plusnet IP Profile is 7.15 but I "only" get 6.72Mbps.  Should I get more (hey, when you're that slow every little helps!)?
bobpullen
Fixes: 316
You should get close to it yes. 6.72Mbps seems reasonable. FWIW, I've checked both your BT and Plusnet profiles and they're configured correctly.
shure
OK.  Many thanks Smiley
robski1
Fixes: 7
Thanks for the Tweak Bob. Smiley
chenks76
All Star
Fixes: 12
how does one check what the BT and plusnet profile you have is?
Oldjim
Resting Legend
Fixes: 63
read the sticky at the top of this board - Speed Faults
