Plusnet IP Profiles that are stuck
Fixes: 10
Re: Plusnet IP Profiles that are stuck
Quote from: Samuria
but should it be 2 meg lower than what I am connecting at?
If you were on ADSL 2+ it could quite correctly be 23 meg lower than your current connection speed - although it would rise again pretty quickly.
The IP Profile is determined by your lowest recent sync speed (typically in the last 72 hours), even if that sync was for a very short time.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Had the following results for the past few days (3 days, 5 hours), think I'm in need of a nudge...
Download speedachieved during the test was - 2068 Kbps
For your connection, the acceptable range of speeds is 1000-99999 Kbps.
Additional Information:
Your DSL Connection Rate :14691 Kbps (DOWN-STREAM), 440 Kbps (UP-STREAM)
IP Profile for your line is - 12000 Kbps
Many thanks,
username - adinther.
Can someone give my profile a kick as per post 358 its still at 5500 even though i connect at 8 meg
Fixes: 10
What is 5500 your IP Profile or your Current Line Speed?
We have been connected to adsl2+ now, can you nudge our profile as its half of what bt have.
thanks
Pebbles
Legend
Fixes: 168
@mwright
Both match at 6000 now.
@bluewhale
Both at 14000 now.
@adinther
Your IP profile is at 12000, as is the one on our side.
@pebbles
Profile is showing at 9000, matched on our side.
Thank you
My profile seems to be stuck - username is stevenharrington
BT speed test Results:
Download speed achieved during the test was - 5282 Kbps
Your DSL Connection Rate :16668 Kbps(DOWN-STREAM), 444 Kbps(UP-STREAM)
IP Profile for your line is - 14000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 17.34:25.98:56.68 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
PlusNet's line profile:
Estimated line speed:
   Not recorded (service activated before we introduced estimates).
Current line speed:
   7150
Can I have a bump please?
Cheers!
* BUMP *
Pleeeeeasssee!!
Fixes: 10
If you ring support they have access to the buttons that need to be pushed.
Hi MacOS10,
Now done - sorry about the delay in picking this up for you.
Hi Matt, Chris et al,
Could you tell us how the profiles are monitored / updated, its just that BT have up'd our profile to 11000, but we are in the middle of our 10 day training period and we don't want to have you running around nudging for us every 5 mins, We were just hoping that it was an automatically updated thing and just needed to catch up.
Cool
