Plusnet Fibre - PPPoE and Linksys E3000 DD-WRT router
- Re: Plusnet Fibre - PPPoE and Linksys E3000 DD-WRT...
05-04-2013 6:50 PM
I have just moved over to plusnet fibre this week - Been waiting over a year for fibre to be connected in my area!
Trying to get my DD-WRT router to work - Hoping its just something I have missed.
I have updated to the latest version available and reset to factory settings before starting.
This is what I have
BT Open Reach (ECI) ---> WAN Port (DD-WRT Linksys E3000) --> Lan
On DD-WRT:
Setup : Basic Setup:
ConnectionType : PPPoE
Username : xxxxdeamer@plusdsl.
Password: empty (have also tried my password)
But it just doesn't connect. I have left it for a couple or minutes but nothing.
Do I need to leave it for a while to 'sync'?
Any other suggestions?
This is what I have
On DD-WRT:
Message 1 of 5
(3,303 Views)
4 REPLIES 4
Re: Plusnet Fibre - PPPoE and Linksys E3000 DD-WRT router
05-04-2013 6:55 PM
Username should be :- xxxxdeamer@plusdsl.net
Password - the one you use to login to the PlusNet Member centre https://portal.plus.net/index_nlp.html
Message 2 of 5
(1,352 Views)
05-04-2013 7:02 PM
Quote from: MisterW Username should be :- xxxxdeamer@plusdsl.net
Sorry the first one was a typo. I must have deleted the .net
Password - I tried with my password and it still didn't connect.
Message 3 of 5
(1,352 Views)
05-04-2013 7:14 PM
My TP-Link can take 3 or 4 minutes to connect.
I usually reboot the modem first and then the router!
Geoff,
York.
York.
Message 4 of 5
(1,352 Views)
05-04-2013 7:35 PM
Quote from: NedLudd My TP-Link can take 3 or 4 minutes to connect.
Thanks!
Got it working now - incase anyone else needs it these are the steps I did:
Switch Everything Off.
Switch BT Open Reach On and wait for 'DSL' light
Switch Linksys E3000 with DD-WRT on and waited for 5 minutes
Came back to PC - working
Message 5 of 5
(1,352 Views)
