Plusnet 582N Modem and Apple Airport Extreme AC ?
- Plusnet 582N Modem and Apple Airport Extreme AC ?
08-10-2014 9:36 AM
Hi, I have had terrible connectivity/wifi dropping with the supplied Plusnet 582N modem (used with standard ADSL copper based broadband). I have been considering the Apple Airport Extreme as I am an Apple fan and have heard very good things about this. Clearly this does not have a modem, so does anyone know what configuration is needed to allow this device to just work as a modem with the Airport managing wifi access, etc
I hear we may get fibre in Dec/Jan so would be also good to understand if I can continue to use this then.
Any help/guidance would be great before I take the plunge and buy one.
Many thanks.
Twen
Many thanks.
Twen
Message 1 of 3
(723 Views)
2 REPLIES 2
Re: Plusnet 582N Modem and Apple Airport Extreme AC ?
08-10-2014 9:46 AM
you put the airport into bridge mode.
then turn wifi off on the 528N
Message 2 of 3
(437 Views)
08-10-2014 9:52 AM
it is that simple, here's mime
this is plugged into the 582 and the wireless is switched off in the 582.
Message 3 of 3
(437 Views)
