Plusnet 2704n router
Hello, I'd like to understand if there is an opportunity to upgrade the existing router I have - the 2704n. I would like to get faster broadband speeds and understand this is a very basic router. Could you help with this? Thanks.
9 REPLIES 9
Fixes: 1,071
Re: Plusnet 2704n router
Your speeds are only partly determined by the router.
If you enter your phone number here https://www.broadbandchecker.btwholesale.com/#/ADSL You should see the expected speeds and if you could get any faster by upgrading to fibre.
Are the speeds you are seeing in line with these results?
Fixes: 43
@kimmysammy Upgrading your router would probably not increase your speed - that depends on the characteristics of your connection.
Plusnet only supply these 'basic' routers, there are no better ones available from them, and in any case, to get a new one, you would have to request one at contract renewal.
If you want one with better wireless performance, it is suggested that you buy a BT HH6 - available for £20-£30 on eBay.
Edit: @dvorak beat me to it.😉
Thanks. This is the result. Might need a hand understanding it.
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper
High Low High Low
VDSL Range A (Clean)  80 69.8 20 19 64.5 Available Available --
VDSL Range B (Impacted)  80 67.2 20 19 61.2 Available Available --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 30 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 7.5 -- 5.5 to 12 Available Available --
WBC ADSL2+ Annex M Up to 7.5 Up to 1 5.5 to 12 Available Available --
ADSL Max Up to 5.5 -- 4 to 8 Available Available --
WBC Fixed Rate 2 -- -- Available Available --
Fixed Rate 2 -- -- Available -- --
Observed Speeds ADSL
Max Observed Downstream Speed 16.01
Max Observed Upstream Speed 0.88
Observed Date 2020-04-18
Other Offerings Availability Date
VDSL Multicast Available
ADSL Multicast Available
Premise Environment Status
Bridge Tap U
VRI N
NTE FacePlate N
Last Test Date 23-06-2020
Fixes: 1,071
So you’re currently on ADSL and your speeds are 16mbps - are these the speeds you’re seeing?
If you upgrade to fibre you should get between 60-80mbps.
I am currently getting around 12mbps on wireless, within a couple of metres from the router, which is performing quite well at the moment. What do you think?
Fixes: 1,071
Doubtful a new router will help much with things as they are currently.
An upgrade to fibre should increase your speeds substantially.
But it also depends on what you’re using the connection for.
Thanks for this! I'll consider options. Contract comes to an end in under two months.
Fixes: 10
I would have thought PlusNet would allow you to upgrade to fibre whilst you're under contract, after all you're still going to a customer to them? I could be wrong though, it is worth contacting support and ask.
Fixes: 48
The real question is why do you think you need more speed?  What perceived problem do you seek to fix?
