PlusNet is NOW faster than TalkTalk for me (was PlusNet Slower than TalkTalk )
- PlusNet is NOW faster than TalkTalk for me (was Pl...
Re: PlusNet Slower than TalkTalk for me :(
15-01-2015 10:21 PM
15-01-2015 10:43 PM
Quote from: ejs When the DSL drops it will be more likely to re-connect at a slightly different speed rather than re-connect at exactly the same speed.
If the drop is caused by a loss of upstream sync, I've seen it reconnect at the same speed.
15-01-2015 11:08 PM
If that defines my re-start of 10days then 18/01/2015 is the end.
Is there any indication that the DLM has finished the 10 day re-training? Like a report or something?
16-01-2015 11:01 AM
16-01-2015 11:10 AM
That event on 8th was just part of the process, which started on 5th Jan with the successful reset.
Quote from: DDNewCust I have had the same connection speeds, which I guess the DLM looks at since the retune on 08/01/2015 @ 05:00
So I would expect it's all done now.
Quote from: DDNewCust OK SNR has reset.
16-01-2015 4:32 PM
"A notification after this period is sent to the RAP profile and your ISP."
Question to CRT does this happen on my line and have you been informed?
And this line is a bit depressing as I know it is currently much lower than I am currently getting. "The MSR is set from the lowest achieved rate over this 10 day period rounded down to the nearest 0.5Mb."
Edit 16:45
I read this under the 20CN MaxDSL section, I know I am on 21CN ADSL2+ line, but suspect the process is the same.
18-01-2015 12:33 AM
As HP has mentioned it started on the 5th with the SNR Reset and ran for 10 days during which time the MSR is defined. During training DLM can change the SNRM up or down depending on line conditions, resyncs will occur if/when those changes take place.
DLM obviously thinks your line is Ok at the moment as it lowered the Target SNRM to 3db quite quickly (resync on the 8th) and that's been held to date.
All 20CN/21CN lines have an MSR. It's only used to define the FTR (Fault Threshold Rate). Nothing to get excited about. It's only 20CN that rounds down. Your MSR should be 12260. All these settings and notifications/reports are automatic, nobody physically looks at them until such time there is a problem or fault raised. Delta reports are sent by the BT servers whenever there is a change in sync speed, not just during the training period.
If you want to fit your Mk3 plate, then go ahead when you have plenty of daylight hours to complete the job. Check before you start that your SNRM is nice and stable at the Target SNRM or above (currently 3dB). Drop the PPP session and then power off the modem/router after about a minute.
Don't forget your modem/router extension socket wiring, the Blue+white trace & White+blue trace, connect to the two IDC terminals on the Mk3 plate. You need to use a micro-filter at that extension socket.
The other fixed phone extension sockets connect to the front plate IDC terminals or plug into the phone socket. Because those connections are filtered you don't need microfilters at the other sockets unless you have phones that need a bell-wire OR you can connect the bell-wire (Orange+white trace) to terminal 3 for the fixed extensions.
18-01-2015 7:27 PM
Quote from: Anotherone Don't forget your modem/router extension socket wiring, the Blue+white trace & White+blue trace, connect to the two IDC terminals on the Mk3 plate. You need to use a micro-filter at that extension socket.
Can I just confirm something first. I was going to make the line to router "ADSL only" wiring the modem connections in directly, both at the MK3 plate A & B and at the Bedroom 4 extension plate (router location). Your post implies (I think) that I could use a rat tail filter Bedroom 4 end. It would be nice to retain the phone, but if the performance is much better or less interference than it will sadly go. If so I could try it with and without the rat tail as a test.
I will take readings before and after as suggest. Although I know the improvement may be reduced drop outs and CRC HEC etc errors.
For Info this is what I have now. including BITs graph
Uptime (from SF Count):
10 days, 02:07:30
Upstream (Tx):
Good Cells: 37496633
Idle Cells: 2322302277
Downstream (Rx):
Good Cells: 517566569
Idle Cells: 2915642848
Bad HEC Cells: 206431
Overflow Dropped: 0
Down
Connection Rate: 13510 Kbps
Line Attenuation: 29 dB
Noise Margin: 3 dB
Max Rate: 13528 Kbps
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 154760
Fast path FEC: 0
Fast path HEC: 0
Up
Connection Rate: 1091 Kbps
Line Attenuation: 17 dB
Noise Margin: 5 dB
Max Rate: 1092 Kbps
Interleave CRC: 0
Interleave FEC: 0
Interleave HEC: 0
Fast path CRC: 0
Fast path FEC: 0
Fast path HEC: 0
18-01-2015 7:55 PM
If you don't have a filter, how will you provide the RJ11 connection that the router cable uses? Or did you buy a socket such as I suggested?
Quote from: DDNewCust Your post implies (I think) that I could use a rat tail filter Bedroom 4 end. It would be nice to retain the phone
The rat-tail filter doesn't really matter as the ADSL wiring is unfiltered, so "sees" the phone signal anyway, whichever extension socket it comes from.
18-01-2015 9:12 PM
Quote from: HPsauce If you don't have a filter, how will you provide the RJ11 connection that the router cable uses? Or did you buy a socket such as I suggested?
I would connect it directly, inside the extension socket by modifying a RJ11 cable, probably shorter. As I believe you suggested or someone else. I have a few of those RJ11 cables hanging around.
I would not use a phone in that socket, unless filtered.
Quote from: HPsauce The rat-tail filter doesn't really matter as the ADSL wiring is unfiltered, so "sees" the phone signal anyway, whichever extension socket it comes from.
If I want the phone there it matters, which was part of the question I was asking.
18-01-2015 9:36 PM
Indeed, you need to have a filter if you put a phone there. But having a phone there will probably make no difference to the ADSL.
Quote from: DDNewCust If I want the phone there it matters
18-01-2015 9:40 PM
Quote from: Anotherone Drop the PPP session and then power off the modem/router after about a minute.
Is the power off router bit preferred to removing the RJ11 out the back of the router and re-plugging it in when the works done? Or is the idea that the router forgets the SNR degraded bins that may have been stored, which now could be good or worse?
19-01-2015 8:19 AM
Quote from: DDNewCust I would connect it directly, inside the extension socket by modifying a RJ11 cable, probably shorter. As I believe you suggested or someone else. I have a few of those RJ11 cables hanging around.
There is absolutely no point in doing that, use a decent rat's tail filter.
Yes, power off is preferred. It primarily prevents any possibility of an "unclean" - in the electrical sense, break or make of the line sync connection which of course can create "noise", but also some modem/routers send a "dying gasp" signal which can be recognised by some DSLAM/MSAN line cards so that DLM doesn't interpret the sync loss as a drop in connection. It's always good practise to do it like that anyway.
19-01-2015 2:14 PM
Tests before Fitting MK3 vDSL Plate
DS Connection Rate: 13510 DS Line Attenuation: 29 DS Margin: 3
US Connection Rate: 1091 US Line Attenuation: 17 DS Margin: 5
Tests after Fitting MK3 vDSL Plate
DS Connection Rate: 14489 DS Line Attenuation: 28 DS Margin: 3
US Connection Rate: 1095 US Line Attenuation: 17 US Margin: 5
So an apparent gain of 979Kbs DS and 4Kbs US.
I think the Bits graphs attached before 9:13 and after 10:18 show why.
There is a lift of the SNRM at the top end Tones 256 to 512 from 0 to 1db, these now have more bits allocated.
But there is a slight reduction in the SNRM from Tones 0 to 256 which is harder to quantify but lets say it's about 0.3db. I guess the reduction on the lower BINs is due to the common mode choke in the MK3 before the ASDL line and the lift is the filter after that point disconnecting the added capacitance of the extension lines.
But an overall gain on my line set-up it appears to be.
The testing on real downloads shows no real improvement at the moment for the near 1Mbs increase in connection rate.
On the ookl tester 11.41Mbs Down 0.97Mbs UP .
BT Force tests 11.6Mbs DL 0.94Mbs UP IP Profile for line is - 12.78 Mbps
Any reason why I am not seeing a near 1Mbs increase in downloads?
19-01-2015 2:30 PM
It takes time for the IP profile to update and propagate to PlusNet, meanwhile the speed is still managed at the old rate.
