Please reset my line
- Please reset my line
Re: Please reset my line
25-06-2015 7:30 PM
25-06-2015 7:51 PM
25-06-2015 8:06 PM
Thanks AO. I will publish stats when the daylight goes.
I've got the Jj11 BT adapter. Should I just leave the rouyter direct off the master or reconfig it back as was. with the BT - Rj11 inline?
Thanks again guys. I will be around a lot more tomorrow - work @ home day!!!
25-06-2015 9:51 PM
> adsl status
--------------------------- ATU-R Info (hw: annex A, f/w: annex A) -----------
Running Mode : ADSL2+(G.992.5) State : SHOWTI
ME
DS Actual Rate : 16016000 bps US Actual Rate : 888888 bps
DS Attainable Rate : 17064000 bps US Attainable Rate : 888000 bps
DS Path Mode : Interleave US Path Mode : Interleave
DS Interleave Depth : 96 US Interleave Depth : 8
NE Current Attenuation : 26 dB Cur SNR Margin : 5 dB
DS actual PSD : 20. 1 dB US actual PSD : 11. 9 dB
ADSL Firmware Version : 2471201_A
-------------------------------- ATU-C Info ---------------------------------
Far Current Attenuation : 14 dB Far SNR Margin : 14 dB
CO ITU Version[0] : 00004946 CO ITU Version[1] : 0000544e
DSLAM CHIPSET VENDOR : < IFTN >
26-06-2015 7:24 AM
So then, do a graceful disconnect and power off the modem/router after a minute. Stay offline for about 10 minutes (or longer) whilst you reconfigure your wiring.
Filter into master socket. Phone into filter. RJ11/BT adapter into filter. CW1308 extension lead/splitter into adapter. Modem/router into a filter into extension socket. Splitter socket remains empty - should you ever wish to plug an additional phone into that, it MUST be via a filter.
Post up your ADSL status data before and after reconfiguring the wiring so a direct comparison can be made.
As far as the SNR Reset goes, that seems to have failed, not uncommon. Obviously Chris will look at that again.
26-06-2015 10:38 AM
The SNRm is still 5 now, so I guess it was a bit coincidental that it was lower when those stats were taken after dark. So stats as per last time.
Will re-do the router connections etc later this morning and hopefully Chris will be in touch re. the line and that odd up sync value,
26-06-2015 11:59 AM
Some loss in speed and still the odd US sync of course.
btw speed test. 12.3 down .71 up 39ms latency
> adsl status
ME
DS Actual Rate : 15837714 bps US Actual Rate : 888888 bps
DS Attainable Rate : 16980000 bps US Attainable Rate : 888000 bps
NE Current Attenuation : 27 dB Cur SNR Margin : 6 dB
DS actual PSD : 20. 2 dB US actual PSD : 12. 4 dB
Far Current Attenuation : 14 dB Far SNR Margin : 16 dB
26-06-2015 12:33 PM
However as expected, there is a marginal drop in sync rate because the SNRM wasn't quite upto 6 when you reconnected. No worries, it is only marginal so at least your new normal setup doesn't appear at this moment to be adding any noise problems.
So, getting an SNR Reset resolved is the next thing, and then monitor your connection.
26-06-2015 12:36 PM
Should I put up another thread to get the SNR reset done?
26-06-2015 12:44 PM
26-06-2015 12:50 PM
26-06-2015 1:25 PM
Quote from: grahamn Thanks AO.
That's always a bad idea in any event bnecause it losses the connection with the background of information leading upto the need/request for the reset.
26-06-2015 1:59 PM
26-06-2015 2:19 PM
WBC 160K - 24M No delay (INP 0) 3dB Downstream, UC No delay (INP 0) 6dB Upstream (ADSL2+)
So the upstream target is 6db.
The other option we could try is capping and then uncapping your upstream, each order for this is 24 hours.
26-06-2015 2:31 PM
I don't understand the implications of each option. I'm hoping to get back to where I was a few weeks back where I had 1Mbps up and about 17Mbps down on a SNRM of 3db.
Thanks.
> adsl status
ME
DS Attainable Rate : 16984000 bps US Attainable Rate : 888000 bps
