Please poke ticket 69872306
- Please poke ticket 69872306
- « Previous
- 1
- 2
- Next »
Re: Please poke ticket 69872306
03-06-2013 10:26 PM
Can you please poke this one again?
I updated the ticket again post the profile refresh providing information requested. That update has not been responded to and in the meantime BTws systems have closed the bb fault. Not ideal really.
Have seen repeated loss of PPP without a loss of synch. Not sure what's happening here - do PN systems identify the cause of the loss of PPP?
03-06-2013 10:42 PM
04-06-2013 3:27 PM
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13703559925886.png"/>
05-06-2013 9:22 AM
Thank you for the radius log. In reference to Saturday morning, does this graph illustrate the known plotting problem when there are too many event points?
There does not appear to be an up event to pair with the noon down event. Is this a too many events to plot issue or does it point to something else?
Can support please look at the dslam synch history to determine / confirm that synch was NOT lost during these periods of no PPP session. Can the reason for PPP loss be identified? The perception I had on Saturday morning when investigating this was synch was up, the router believed PPP was up, but clearly there was no connectivity. I force dropped the PPP session and reconnected ad all was OK. I then departed and as shown by the plot, PPP connectivity was lost again about 13:15. Critical questions "why" and "was synch lost or maintained"?
I believe that the re establishment of PPP on Sunday afternoon was achieved without human intervention... But that does not rule out the possibility that the router self rebooted!
Ref your comment about support picking this up, the last update to the ticket (16:13 yesterday - after your update here) did not address the questions raised on the ticket, rather it only sought to (inadequately) respond to the US data rate question.
In respect of US data speed, I am not asking what is considered to be generally thought to be acceptable rather I am asking what is correct for my line given the available data?
US synch is 0.832Mbps
BT US profile is 0.83Mbps
Data transfer rate is 0.48Mbps
I know that a miss-alignment of the PN profile and BT profile on the DS side does inhibit effective use of the data transfer capacity. Does a similar consideration exist for US profiles? If it does, is there a need for something to be adjusted somewhere or is the BT profile (which matches the synch speed) wrong?
Cheers,
Kevin
05-06-2013 12:28 PM
05-06-2013 5:08 PM
You should be seeing speeds closer to your upload IP profile, do you have anything other programs running while you're running a speed test?
05-06-2013 5:47 PM
No, to the best of my knowledge nothing else was running during the speed test.
Kevin
06-06-2013 9:30 AM
06-06-2013 9:41 AM
Ok thanks, will do.
Does your answer mean you do not have an US profile recorded fr my service, but you should have or that US profiles are not kept by PN at all?
I guess that if the prime purpose of the DS profile is to prevent PNs systems sending data faster than the line can confidently support, then there is no similar purpose for PN recording an US profile?
Kevin
06-06-2013 11:11 AM
06-06-2013 11:17 AM
Would have been nice to have had such a clear answer on my original ticket. So much to learn and understand around here. So the real question I need to bottom out is why is my end not using all of the available US synch... will try to get another test done and in the meantime keep taking the happy pills!
Cheers,
Kevin
06-06-2013 11:48 AM
06-06-2013 11:53 AM
- « Previous
- 1
- 2
- Next »
