Please Tell Me Your Wired vs Wireless Speeds (80/20 Fibre)
- Re: Please Tell Me Your Wired vs Wireless Speeds (...
27-09-2012 11:48 AM
I am looking for people who are on 80/20 fiber to tell me what speeds their typically get on wired and again on wireless. A few replies would be sufficient.
Thanks in advance.
Thanks in advance.
Message 1 of 6
(1,006 Views)
5 REPLIES 5
Re: Please Tell Me Your Wired vs Wireless Speeds (80/20 Fibre)
27-09-2012 11:59 AM
80/20 sync, 77/20 profile, 73-75/16 wired speeds (on speedtest.net), 24/15 typical wireless speeds (on same), but more variable. The wireless will be 802.11g, or 54Mbps.
Plusnet Customer
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
Message 2 of 6
(519 Views)
27-09-2012 12:07 PM
75/20 profile, 70/17 wired speeds (on speedtest.net), 34/15 typical wireless speeds (on same), but more variable. The wireless will be 802.11g, or 54Mbps
Thanks for the template WWWombat
Message 3 of 6
(519 Views)
27-09-2012 12:13 PM
Thanks people. Could you tell me what router and wireless adapter you're using?
Message 4 of 6
(519 Views)
27-09-2012 12:15 PM
Macbook pro internal wireless with the Netgear PN supplier router (N100?)
Message 5 of 6
(519 Views)
27-09-2012 12:44 PM
My router will be the original Netgear WNR-1000 i think (an N-based wifi router).
The adapter at the laptops are unknown, as they're built-in. My usual one is a 6 year old HP, and definitely only G-capable.
Plusnet Customer
Message 6 of 6
(519 Views)
