Please Raise Fault To BT
- Please Raise Fault To BT
Re: Please Raise Fault To BT
01-11-2010 3:21 PM
but i think i'd rather just have my ping lower than better speed tbh
also is 21CN enabled on my exchange yet ? as samknows says its enabled but then says 31/03/2011 but PN says sept 2010
http://www.samknows.com/broadband/exchange/NSASH
cheers.
[Moderator's note by Dick (Strat): Full quote of preceding post removed, as per Forum Rules ]
01-11-2010 3:47 PM
Your exchange is enabled for ADSL2+ but bearing in mind the errors you may be opening up a can of worms moving on to it.
Jojo
01-11-2010 3:58 PM
well if ADSL2+ does go bad can i go back to adslMAX on 21cn network?
if so i would like you to put the order through for ADSL2+ please
alxns
01-11-2010 4:10 PM
If you are having issues and don't anticipate getting a significant increase in speed I'd STRONGLY recommend sticking with 20CN until BT get 21CN working properly!
01-11-2010 4:12 PM
I have placed the order for you. It normally takes 7 days to take effect.
Jojo
01-11-2010 4:21 PM
As one of the inherent advantages of ADSL2+ is the speed boost attainable on longer/poorer phone lines i will hope for something better but if not well thats the risk you take guess
i will update here on the 8th or 9th to let you know if anything has changed
thanks.
01-11-2010 4:26 PM
01-11-2010 4:28 PM
It's 47dB
Jojo
01-11-2010 4:31 PM
I'm damned sure I wouldn't take the risk with the current state of 21CN!
Alxns: You need to be aware that the 21CN DLM seems to be far more aggressive, so if you do get errors on the line, and don't have interleaving put on your target noise margin will shoot straight up.
01-11-2010 4:42 PM
Jojo
01-11-2010 5:27 PM
Quote from: Joanne Your exchange is enabled for ADSL2+ but bearing in mind the errors you may be opening up a can of worms moving on to it.
I was trying to back you up as he'd not seemed to appreciate what you were saying. At least he is fully aware of the risks now.
01-11-2010 9:04 PM
but due to my line can barely handle 3.5 mbps never mind the predicted 4.5mbps from kitz
i'm really hoping it will give me more lee way with errors also the upload speed is a must for me in general
but thanks for the concern guys.
01-11-2010 9:53 PM
04-11-2010 7:47 AM
Borrowed Netgear
04-11-2010 10:25 AM
