Please Help: Use Technicolor TG582n as repeater with another Technicolor TG582n
- Re: Please Help: Use Technicolor TG582n as repeate...
01-07-2013 9:42 PM
I have 2 fibre router and I only use one since broadband was installed, however the wireless signal in my house is really poor and am looking to use the second router as a wireless repeater.
would this be possible such that I can access my home network and files through the repeater if possible?
I ve searched and searched but havent found anything yet. Please advice.
Thanks in advance.
Thanks in advance.
Message 1 of 4
(4,917 Views)
3 REPLIES 3
Re: Please Help: Use Technicolor TG582n as repeater with another Technicolor TG582n
02-07-2013 12:21 AM
This may help:
http://npr.me.uk/together.html
Connect the two together via ethernet cable or a pair of homeplugs.
It is possible to connect them by wireless (WDS) but this gives very poor result, I really would not recommend this method.
http://npr.me.uk/wds.html
Message 2 of 4
(743 Views)
02-07-2013 12:29 AM
My home setup is:
Thomson ---> Powerline adapters ----> old router (bt home hub 3) ---> wireless network coming from bt home hub.
I guess you could do something similar, you can even get powerline adapters that are wireless now as well.
Alternatively - you could connect them via an ethernet cable as mentioned above.
Message 3 of 4
(743 Views)
02-07-2013 10:21 AM
Npr.. Thanks so much for the Link works perfect, However I left the channel as Automatic on both router and so far I haven't experience any problem. Fingers crossed. Thanks a lot for your help.
Message 4 of 4
(743 Views)
