Platte Media
- Re: Platte Media
Platte Media
07-04-2008 7:45 PM
Has anyone else had this problem?
I'd really appreciate some advice ......
Re: Platte Media
07-04-2008 7:54 PM
http://mbsvictims.org.uk/index.php?topic=6.0
If it is this, best of luck...
[EDIT]
Think your first point of call should be using system restore to get back to a point before you saw this appear.
Re: Platte Media
07-04-2008 8:38 PM
The best thing to do is to turn system restore off, then run the virus scanner, remove the virus if at all possible and then once the system has been confirmed clean, system restore can be safely turned back on.
Re: Platte Media
07-04-2008 8:47 PM
Re: Platte Media
07-04-2008 8:55 PM
Re: Platte Media
07-04-2008 9:13 PM
Re: Platte Media
07-04-2008 9:14 PM
is an excellent source of information on this disreputable company, and the way it works.
It has various methods of removing the "problem" which includes running AVG and anti-spyware, malware removals, etc.... the favourite seems to be prevx which is a link on some of the replies and although I have not been there, probably a good starting point....
The site mbsvictims.org.uk is a forum site (similar to this one) and it is very helpful to those "in distress"....
Well worth a visit...... for advanced information..... and put it in your favourites/bookmarks list "just in case"
Re: Platte Media
08-04-2008 4:21 PM
Re: Platte Media
10-04-2008 6:05 PM
Thanks again sooo much for helping a silver surfer!
Re: Platte Media
10-04-2008 6:38 PM
From another "silver surfer"
