Pitiful Upload speed
chickendippers
My upload speed is unusably slow, but the download speed seems fine. I'm currently on the "Unlimited" ADSL2 product.
I appreciate your time to check these stats:
5533850378
5. DSL uptime: 7 days, 05:56:35
6. Data rate: 443 / 16293
7. Maximum data rate: 1076 / 16224
8. Noise margin: 25.6 / 6.0
9. Line attenuation: 11.3 / 22.8
10. Signal attenuation: 11.3 / 21.0
11. Data sent/received: 565.5 MB / 10.8 GB
12. Broadband username: *Redacted*
13. 2.4 GHz Wireless network/SSID: *Redacted*
14. 2.4 GHz Wireless connections: Disabled
15. 2.4 GHz Wireless security: WPA2
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 5 GHz Wireless network/SSID: *Redacted*
18. 5 GHz Wireless connections: Disabled
19. 5 GHz Wireless security: WPA2
20. 5 GHz Wireless channel: Automatic (Smart Wireless)
21. Firewall: Default
My research seems to suggest that with a Maximum Upload Data Rate of 1076 I should be achieving a better actual upload speed. Further diagnostics below (plus one funny picture I took outside the Plusnet office this week)
Thanks in advance.
BT Speedtest Results 06/08/2016BT Speedtest Results 06/08/2016BT Speedtest Advanced Diagnostics Results 06/08/2016BT Speedtest Advanced Diagnostics Results 06/08/2016Plusnet Broadband Fault Checker 06/08/2016Plusnet Broadband Fault Checker 06/08/2016It seems someone at the council is a Plusnet customerIt seems someone at the council is a Plusnet customer
7 REPLIES 7
Oldjim
Resting Legend
Fixes: 63
Re: Pitiful Upload speed
you need to contact Plusnet to get your upload uncapped - when it was ordered a mistake was made
chickendippers
Thanks for the suggestion. I spoke with two Plusnet representatives, the first of whom told me the line was not capped. The second advised:
This did look like it was capped but unable to place an order due to the fibre order that is already in place.
I cannot operate with such a low upload speed for another 7 days until my fibre order is provisioned. I'd appreciate if this could be escalated and resolved in the mean-time.
Thanks!
Oldjim
Resting Legend
Fixes: 63
unfortunately the BT Openreach system will only allow one order at a time so you are stuck
chickendippers
Cry
Why would an upload speed be capped so low? That is not sufficient to play online computer games these days: https://support.rockstargames.com/hc/en-us/articles/200525767 and I have tried!
ankado
I have an upload speed of 0.36
Plusnet told me yesterday that they are not interested in upload speed, only download.
Just about to pull the plug anyway.
MatthewWheeler
Fixes: 480
@chickendippers Unfortunately or fortunately depending on how you look at it you have a upgrade to fibre in place which stops us from placing a order to uncap your upload.
@ankado If you can PM me your username I'll see what I can do.
 Matthew Wheeler
chickendippers
Hi Matthew,
Thanks for the confirmation. I'll add this to my list of complaints which I will be raising once everything if finally sorted.
Considering how many of my problems Plusnet have blamed on BT Openreach, I'm surprised to find you are not members of the Fix Britain's Internet campaign to do something about it!
