Pings now worse on Metronet Titanium service - Anyone else
- Re: Pings now worse on Metronet Titanium service -...
06-01-2008 10:34 PM
If it still exists, gaming packets were supposed to be prioritised on the Titanium service from Metronet and James did a good job of getting my packets recognised.
Anyone else seen a problem?
phoenix1963
Re: Pings now worse on Metronet Titanium service - Anyone else
07-01-2008 10:07 AM
Could you possibly supply a traceroute and some ping requests to the server that you are trying to use?
You do do this by opening a command prompt and typing tracert server address and ping server address (using the IP address of the server in question.
07-01-2008 4:49 PM
My game pings were typically ~95 (goodish) before I was Maxed, 110 (could live with this, no interleaving) after being Maxed, and now ~120-130 which is borderline.
Here are the ICMP pings and traceroute:
Pinging 69.90.34.220 with 32 bytes of data:
Reply from 69.90.34.220: bytes=32 time=246ms TTL=119
Reply from 69.90.34.220: bytes=32 time=126ms TTL=119
Reply from 69.90.34.220: bytes=32 time=133ms TTL=119
Reply from 69.90.34.220: bytes=32 time=209ms TTL=119
Ping statistics for 69.90.34.220:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 126ms, Maximum = 246ms, Average = 178ms
Reply from 69.90.34.220: bytes=32 time=131ms TTL=119
Reply from 69.90.34.220: bytes=32 time=129ms TTL=119
Minimum = 126ms, Maximum = 131ms, Average = 128ms
Tracing route to 69-90-34-220.ny.atlasservers.com [69.90.34.220]
over a maximum of 30 hops:
1 <1 ms <1 ms 1 ms home [192.168.1.254]
2 35 ms 31 ms 37 ms lo0-plusnet.ptn-ag1.plus.net [195.166.128.123]
3 39 ms 37 ms 41 ms ge0-0-0-303.ptn-gw01.plus.net [84.92.3.9]
4 43 ms 45 ms 35 ms ge1-1-0-32.ptn-gw2.plus.net [195.166.129.12]
5 35 ms 35 ms 33 ms gi12-0-904.ptn-ag2.plus.net [212.159.1.106]
6 32 ms 35 ms 43 ms linx-gw1.peer1.net [195.66.224.156]
7 122 ms 122 ms 125 ms 216.187.115.33
8 123 ms 121 ms 123 ms oc48-po3-0.nyc-75bre-dis-1.peer1.net [216.187.115.134]
9 125 ms 131 ms 127 ms 216.187.115.145
10 125 ms 135 ms 127 ms 69-90-34-220.ny.atlasservers.com [69.90.34.220]
Trace complete.
Cheers,
phoenix1963
07-01-2008 4:54 PM
I'll probably never leave
The traceroute you've supplied doesn't look bad. The response time increase as soon as your traffic crosses the Atlantic, which is what you would expect.
Are there any UK servers that you can try?
What are your general broadband speeds like? Are these as you would normally expect, or have they worsened?
07-01-2008 5:34 PM
I'm near Leeds on LLU
07-01-2008 5:35 PM
10-01-2008 10:29 PM
Quote from: Gloria The traceroute you've supplied doesn't look bad. The response time increase as soon as your traffic crosses the Atlantic, which is what you would expect.
Yes, but it is the consistent increase that disturbs me.
Quote from: Gloria Are there any UK servers that you can try?
Yes, I've tried a UK one with a ping of about 40-odd ms, even there I get what seems to be an unusual amount of stuttering, almost as some packets are being delayed....
Now, my router reports that my connection is now interleaved - when I was Maxed my S/N target was set to 16dB and I asked not to be interleaved. Here is what has changed I suspect!
My router has downstream S/N margin of 12dB (24 db upstream) at a speed of 7616 kb/s.
I would rather have a lower bulk speed and no interleaving please James!
Thanks,
phoenix1963
10-01-2008 11:22 PM
phoenix1963
11-01-2008 10:16 AM
This was picked up by one of our nightshift staff last night. Your order should complete on Monday morning, one working day from when it was placed.
Let us know how you get on then.
11-01-2008 9:54 PM
1 <1 ms <1 ms <1 ms my.router [192.168.1.1]
2 21 ms 22 ms 23 ms l1.ar02.gs1.dsl.pipex.net [62.241.161.244]
3 22 ms 21 ms 21 ms ge-2-1-3.cr02.gs1.dsl.pipex.net [62.241.161.106]
4 22 ms 21 ms 22 ms pc9-104.cr05.tn5.bb.pipex.net [62.72.139.113]
5 30 ms 29 ms 30 ms te1-4.cr01.nik.bb.pipex.net [62.72.137.250]
6 31 ms 29 ms 30 ms ams-sara-cor-1.peer1.net [195.69.145.209]
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 120 ms 120 ms 119 ms 69-90-34-220.ny.atlasservers.com [69.90.34.220]
He goes via Amsterdam(!), but his link to peer1 is quicker.
James - look forward to trying it out on Monday.
phoenix1963
11-01-2008 10:01 PM
in simple terms please.....................
sorry ignore question - if it is to do with games - I don't do games [well, apart from scrabble, patience!]
why is it on this forum - shouldn't be on the games one?
11-01-2008 10:16 PM
11-01-2008 10:19 PM
14-01-2008 11:12 PM
James - Now on Fast (non-interleaved) - much improved gaming, much less stuttering. Gaming pings down to 106-110ish
Thank you!
phoenix1963
14-01-2008 11:14 PM
phoenix1963
