Ping times?
- Re: Ping times?
Ping times?
16-07-2012 1:05 AM
Hi all
When I do a speed test with the BT Beta tester of Ookla I get a ping of 39ms, now my DL is Interleaved (depth 16). Is 39ms about right for this situation?
I have pinged some UK based sites and they return a similar time but at the moment anything in the USA varies from 95ms to >170ms, so is there an issue for sites across the pond tonight or is this 'normal'???
Message 1 of 9
(5,905 Views)
8 REPLIES 8
Re: Ping times?
16-07-2012 1:59 AM
Better to use dos ping or tracing tool, the bt tester is not reliable for ping results. As to the ping to the US of A, yes that is normal, at best you should see around 100ms from an external ping trace to a US server and add on 15-20 for the actual in game ping.
FTTP 500 regrade from Tues 28th November
Message 2 of 9
(704 Views)
Re: Ping times?
16-07-2012 8:19 AM
On Windows pathping is the best bet.
Message 3 of 9
(704 Views)
Re: Ping times?
16-07-2012 9:29 AM
Thanks both
So 39ms is about right for my "connection" for UK sites, yes? NB I do not game online but always hope my connection is up to good standard
As for ping method, I used the ping command in W7 DOS CMD window.
Message 4 of 9
(704 Views)
Re: Ping times?
17-07-2012 9:46 AM
@Routefinder
What results did you get from the speed tests just out of interest? I'd say from looking at the results of a line check that I've just performed that 39ms is not unreasonable for your line IMHO.
Quote So 39ms is about right for my "connection" for UK sites, yes?
Message 5 of 9
(704 Views)
Re: Ping times?
22-07-2012 11:37 PM
Hi Adam
FWIW I still find it hard to appreciate that with sync of 3755 and the 88.2% of sync IP at 3.31 why my measured speed (depending on the test tool) barely gets above 3Mbps i.e. why the heck is it not rountinely closer to the IP figure!!! There being very little difference based on the time of day so by inference exchange contention & network congestion are not obviously a factor or are they based on the info I have given???
NB Just to mention in case it has any relevence, I am on a Legacy Product Premier Option 1 and my usage is primarily ~ surfing, email, VPN during office hours though that can go up to say 9pm sometimes, limited amount of FTP and likewise not a lot of streaming. Considering switching Plusnet Extra Pro as that will save me money especially being on a Market 2 exchange......................so in the same respect would the newer package have an impact performance wise???
So sorry for the delay but I did some tests as below on the 17th July and the 18th July for your perusal and many thanks in advance for your insight & guidance:-
17th July 2012
BT Tester @ 22:09hrs
DL 2.96
UL0.37
IP 3.31Mbps
BT Beta Tester
DL 3.12
UL 0.38
Ping 52.50
BT Beta Tester a minute later
DL 3.11
UL 0.38
Ping 42.50
Ookla @ 20:54hrs
DL 3.11
UL 0.38
Ping 39ms
TBB Tester
Java @ 20:56hrs
DL 2.9
UL 0.4
Flash @ 20:58hrs
DL 3.02
UL 0.37
18th July 2012
BT Tester @ 01:19hrs
DL 2.94
UL 0.37
IP 3.31Mbps
BT Beta Tester @ 01:17hrs
DL 3.11
UL 0.36
Ping 37.50
Ookla @ 01:20hrs
DL 3.11
UL 0.38
Ping 39ms
TBB Tester
Java @ 01:21hrs
DL 3.0
UL 0.4
Flash
DL 3.02
UL 0.36
18th July 2012
BT Tester @ 11:40hrs
DL 2.97
UL 0.23
IP 3.31Mbps
BT Beta Tester @ 11:41hrs
DL 3.12
UL 0.38
Ping 51.75
Ookla @ 11:42hrs
DL 3.11
UL 0.38
Ping 38ms
TBB @ 11:44hrs
Java
DL 3.0
UL 0.4
Flash
DL 3.02
UL 0.37
And here is the current RouterStats data as at 22nd July 23:25hrs
DL
Noise Margin: 3.7 dB
Connection Rate: 3755 Kbps
Line Attenuation: 56.0 dB
Power: 0.0 dBm
Max Rate: 4672 Kbps
SuperFrames: 117644604
SF (CRC) Errors: 7220
Reed Solomon: 3823449634
RS Corrected: 74481781
RS Un-Corrected: 73743
HEC: 6536
Errored Seconds: 3086
Severe ES: 20
Interleave Depth: 16
Bitswaps: 31311
UL
Noise Margin: 12.6 dB
Connection Rate: 444 Kbps
Line Attenuation: 29.3 dB
Power: 12.8 dBm
Max Rate: 640 Kbps
SuperFrames: 105894560
SF (CRC) Errors: 0
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 1
Bitswaps: 71348
Uptime
Total Uptimes (From SF counts):
WAN: 23 days, 03:33:36
LAN: 23 days, 03:33:36
CRC: 7220
LOS: 1
LOF: 0
ES : 3086
17th July 2012
DL 2.96
UL0.37
IP 3.31Mbps
BT Beta Tester
DL 3.12
UL 0.38
Ping 52.50
DL 3.11
UL 0.38
Ping 42.50
Ookla @ 20:54hrs
DL 3.11
UL 0.38
Ping 39ms
TBB Tester
Java @ 20:56hrs
DL 2.9
UL 0.4
Flash @ 20:58hrs
DL 3.02
UL 0.37
18th July 2012
DL 2.94
UL 0.37
IP 3.31Mbps
DL 3.11
UL 0.36
Ping 37.50
Ookla @ 01:20hrs
DL 3.11
UL 0.38
Ping 39ms
TBB Tester
Java @ 01:21hrs
DL 3.0
UL 0.4
Flash
DL 3.02
UL 0.36
18th July 2012
DL 2.97
UL 0.23
IP 3.31Mbps
DL 3.12
UL 0.38
Ping 51.75
Ookla @ 11:42hrs
DL 3.11
UL 0.38
Ping 38ms
TBB @ 11:44hrs
Java
DL 3.0
UL 0.4
Flash
DL 3.02
UL 0.37
DL
Power: 0.0 dBm
Max Rate: 4672 Kbps
HEC: 6536
Severe ES: 20
Bitswaps: 31311
UL
Power: 12.8 dBm
Max Rate: 640 Kbps
SF (CRC) Errors: 0
Reed Solomon: 0
RS Corrected: 0
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 1
Bitswaps: 71348
Uptime
CRC: 7220
LOS: 1
LOF: 0
ES : 3086
Message 6 of 9
(704 Views)
Re: Ping times?
23-07-2012 11:41 AM
It's good to see that your line is performing close to the 3312kbps IP profile, I can't be sure as to why it's a little under that at present though.
Our products should have no bearing over your throughput speed so I'd not consider that to be a factor at all.
Has the latency improved since you first posted as I'd expect a little better than 39ms on a 3.1mb connection.
Message 7 of 9
(704 Views)
Re: Ping times?
23-07-2012 12:14 PM
Routefinder: How far are you from London - that is most likely to be the most significant factor affecting your latency.
Adam: When you do a Windows ping the size of the packet sent and returned on the line is 74 bytes. On a 256kbps up and down line that packet will take less than 2ms to be sent in each direction and that is only the handful of kilometres at most to the exchange. From the exchange to your gateways the speed will be the same (regardless of the users connection speed) and unless the user lives in East London that will be a considerably greater distance. The maximum difference in latency between a line with a sync of 256kbps and one with a sync of 24Mbps (on the same exchange) is going to be 4ms.
Message 8 of 9
(704 Views)
Re: Ping times?
23-07-2012 7:09 PM
Hi both
Adam ~ I will do a few pings over the next day or so and post the results including the location pinged. As for the performance....................well its lower than "close' to the IP is not "at present" it has effectively always been like that since going 21CN. I think under 20CN the two figures were much closer together???
Jelv ~ as the crow flies I am about 20 miles from London as we are in Surrey. AFAIK my connection goes via a main point (PoP) in Reading Berkshire
Message 9 of 9
(704 Views)
