Ping spiking - am I being throttled?
Fixes: 9
Re: Ping spiking - am I being throttled?
@alan666 do you know the ip of the server you are playing on, and the start of you ip (www.whatismyipaddress.com) just the first 3 groups of ips is enough e.g 54.34.56.x
Hi, this is the ip I am getting 80.229.170.84
the start of my ip is 192.168.1
Sorry did that totally wrong, how do i find the ip of the server i am using for gaming?
The ip I sent was done through the link you set using my laptop .
Fixes: 9
The game server ip is a little harder if the game doesn't tell you, on a pc you can use wireshark but can't do that on an Xbox/ps
If we can get the server ip can see if others get he same latency jump or not, and can also look up their network provider and check their routing back etc.
Thanks, I will take a look to see if I can get the game server.
Hi @MrSilver , I have had no look finding the server ip Sad
Just thinking about this logically and came to the conclusion that the 152ms latency can not be game related as I still get 152ms  with no game inserted in to the xbox ?
Fixes: 157
Just so folks are aware, we've got a ticket raised for this one and are looking into it (ref: 96870)
Just FYI I have been having the same problems over the last week playing BF1. I used to consistently get 15-30 ping and now this seems to be 60-200, averaging about 120 in the evening but has spiked up to 200.
same here, it does not matter which game I am playing I get serious lag etc, my latency is 150-180ms
Fixes: 157
Should be fixed.
I noticed Thursday night my ping was back to around 18ms, so looks good now - although when I checked my router diagnostics 'ping default gateway' still came up as failed. Is that something I need to address or is that normal?
