Pilot tone missing. (nothin to worry about or bad as it gets?)
- Pilot tone missing. (nothin to worry about or bad ...
04-01-2009 2:20 PM
All was o.k before xmas. so i have done the only thing i could think off and power off any new electrical things gained over xmas and that hasnt solved it.
The strange thing thoe is the upload tones before this where the other way round most the tones used now where not used and the tones not used now where.
i did have old dmt captures of this but have done a clean vista install and forgot to back up some folders.
Message 1 of 3
(866 Views)
2 REPLIES 2
Re: Pilot tone missing. (nothin to worry about or bad as it gets?)
04-01-2009 3:28 PM
I don't think there's anything wrong (have you noticed any change in performance?). Unfortunately I don't get the bit loading values plot or the gap list with the router I'm on at the moment, but from what I recall it's OK. Someone posted some similar captures on a thread a while back but for the life of me I can't remember where. Hopefully someone will come along whose memory for all this is better than mine
Message 2 of 3
(330 Views)
04-01-2009 10:38 PM
nope performance seems the same. iam sure i read some where that the pilot tone is important on adsl2+.
o well if it anit broke dont fix it.
Message 3 of 3
(330 Views)
