Phone or BB fault
- Phone or BB fault
Re: Phone or BB fault
31-07-2012 10:35 AM
31-07-2012 11:08 AM
As it states in your ticket, there was no fault found at your premises. I don't have the engineer notes to hand. Your line has certainly become more stable. It's just a case of making sure everything is OK, then I'd say tomorrow we can do the SNR reset.
01-08-2012 12:12 PM
01-08-2012 12:13 PM
01-08-2012 12:17 PM
Chris
01-08-2012 1:57 PM
01-08-2012 4:54 PM
Will continue to monitor
01-08-2012 5:15 PM
01-08-2012 9:04 PM
Had a call later this evening, but no sync drop (previous sync had poor upstream), and checked for noise after the call, and line appeared clean. Maybe the calls are clearing up a dodgy connection somewhere on the lines route. Hope its not from the pole to the joint on the 'D' side, as the POTS engineer told me this part of the line on my estate, is just buried, and its not in ducting.......
Anyhow, i think we need to move forward here, with full 'E' side and cab checks, and checks of the tie-pairs. Previous fault like this in 2010, ended up being a frames issue.....
Current syncs 6215/256
02-08-2012 9:21 AM
Quote with full 'E' side and cab checks, and checks of the tie-pairs.
We can't directly request that such checks are done but they should be done if deemed to be an issue by any SFIs looking into your fault.
I can see that the ticket on our side is still with the faults team so we should have a response for you soon.
02-08-2012 10:23 AM
02-08-2012 4:46 PM
02-08-2012 7:47 PM
03-08-2012 9:04 AM
Stats show a number of dropped connections yrsterday and 1 thia morning at 00:30
03-08-2012 9:31 AM
This is a log of your connections:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13439818995511.png" />
I have also made the faults team aware of your fault what took some time to resolve previously, but this does not seem related.
Chris
