Phone issues, please help
- Phone issues, please help
06-08-2007 5:54 PM
Hi, this is probably a case of me being thick, but can anyone tell me if my phone is supposed to work at the same time as I'm using my broadband connection???
Basically my broadband won't work when a call is made / taken until the phone has been hung up again. But I always thought you should be able to use both devices simultaneously?
I have a microfilter coming out of what I think is the master socket in the lounge (it's the only one which has a BT logo on it) and just the modem and the phone on that.
We have a Sky box plugged into a second wall socket in the lounge - does this need to have a microfilter too? There is a 3rd socket upstairs which isn't used.
Any help would be much appreciated.
Message 1 of 5
(2,321 Views)
4 REPLIES 4
Re: Phone issues, please help
06-08-2007 5:56 PM
You need to filter all of your telephone socket, otherwise you can experience issues such as you currently are.
I'd try filtering all the sockets first and see how you get on.
Message 2 of 5
(556 Views)
06-08-2007 6:10 PM
OK will do, but you're saying that I should be able to use the phone and the internet at the same time?
Message 3 of 5
(556 Views)
06-08-2007 6:12 PM
Absolutely - this is one of the main reasons for upgrading from dialup to broadband. Provided filters are installed on every used phone socket you should be able to use the phone without affecting the broadband at all.
Hope this helps,
Hope this helps,
Message 4 of 5
(556 Views)
07-08-2007 12:50 AM
I'd be inclined to plug a micro-filter into the unused socket upstairs too. It isn't strictly necessary, but some day it is bound to happen that a phone will be plugged in there and your broadband will stop working when a phone call is in progress.
Plugging a micro-filter in "just in case" would avoid the confusion/frustration in diagnosing the cause of the problem.
David
Message 5 of 5
(556 Views)
